Results 1 to 8 of 8
    Apr 2012
    A/C Compressor - Connection Broken
    Hello all,
    Been on this forum since I purchased an A3 a year ago. Not need to post till now. Information on here has been very useful.
    Currently got an issue with the A/C Compressor having the connector broken off.
    I know this is a long shot but trying to search for the part below.
    Don't mind getting a compressor from eBay but trying to save having to degas, vacuum and re-gas the system. Plus it had a new clutch fitted.
    Part No:
    Sanden 8676F
    1K0 820 803 Q
    Engine:
    2005 2.0 BKD
    Thanks for all the help.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    perhaps open up connector, expose and crimp wires, then mate with the wiring loom.
    Apr 2013
    Aberdeenshire
    592
    Do you mean the control valve connector has broken off or the clutch connector is broken
    Apr 2012
    Quote Originally Posted by MrLapou View Post
    Don't mind a little DIY but thats a little too advance for me lol.
    Apr 2012
    Quote Originally Posted by Chillout View Post
    Its the Control Valve Connector which has broken off.
    Apr 2013
    Aberdeenshire
    592
    Well I would just do as mrlapou said I take it clutch is engaging and your system is fully charged an easy way to tell if its fully charged is to run your fans full blast and look for sweating/condensation on your suction line.
    the compressor you have is variable displacement it loads and unloads according to heat load via the control valve.
    Apr 2012
    Not got a clue if the clutch is engaging. Its never worked since I had the car. System is fully charged. Clutch replaced as it was faulty.
    Taken look and the connection is completely sheered off back to the housing. So trying to get the connector to be exposed is going be tricky. From what I now understand to replace the Control Value the system needs to be degassed.
    So think I'm going to get a second hand compressor off eBay to save anymore hassle.
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by Trim View Post
    If your clutch is engaging you will see a slight dip in engine rpm and hear the click some clutches you can see the centre spinning when engaged maybe you should have your car scanned for faults as it will show if the clutch is being held off by hp or lp safety's .
    you will have to have the system reclaimed to change the compressor or the valve .
  1. air con compressor broken
    By chunk090883 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th April 2013, 15:19
  2. Replies: 6
    Last Post: 3rd September 2012, 10:08
  3. Bit broken off A3 compressor (Sanden) - Fixable???
    By tates1979 in forum Air Conditioning
    Last Post: 8th August 2009, 23:16
  4. Broken Turn Signal Replacement
    By ozzy in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th December 2003, 17:16
  5. Arial connection
    By gburgess in forum In-Car Entertainment
    Last Post: 1st November 2003, 18:32
