Badger5AH Fabrications
    Mar 2013
    30
    Another 'Will these fit' thread
    First off, I'm relatively new to this forum so hi all!
    I was looking at buying some Rs6 alloys (reps)
    They are 18 x 8.5J (ET38)
    Will they fit?
    Sep 2012
    Milton Keynes, United Kingdom
    47
    Quote Originally Posted by LaytonA3 View Post
    Will they fit?
    I think You will need some 2 mm spacers bud , not 100 % tho
    I i
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    Quote Originally Posted by Black View Post
    I i
    Hi Buddy and welcome to ASN! If you were to add 2mm spacers, that would effectively change the offset to ET36, which would make the wheels stick out even more in the arches. I ran 8x18" ET44 BBS CK's with 225/18/40 tyres and even these rubbed slightly, so my advice would be to look at other options as those wheels you're thinking of are another 1/2" wider so would deffo rub. For 18x8" wheels, the lowest offset without any rubbing would be ET45. You could get away with a slightly lower ET if you run lower profile tyres (ie 215's), but I would say that an 8.5" rim with ET38 is a no no for the A3/S3, unless you want to do some arch work, etc. Hope this helps. Paula xx
    MY10 S3 8P3 S-TRONIC, IMOLA YELLOW
    SHARK PERFORMANCE STAGE 2
    - GONE BUT NOT FORGOTTEN!
    Mar 2013
    30
    Nice one, thanks for clearing that up. Much appreciated and saved me alot of hassle
    Paullie's Avatar
    Banana Menace!
    Jan 2011
    Aberdeenshire
    2,088
    No probs, you're very welcome. Paula xx
  1. Another "will they fit" thread, 8.5x19"
    By Mikey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th August 2008, 11:35
  2. Dials - Will these fit
    By necroeire in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th May 2006, 21:02
  3. i want to upgrade my headlamps but will these fit??
    By aldo8 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2005, 07:53
  4. Will these fit?
    By Anito in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2004, 23:03
  5. will these fit in my trunk?
    By bethishott in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2003, 21:46
