Results 1 to 15 of 15
    Apr 2013
    mansfield
    87
    How do i enable dash display 2006 a3.
    I have a 2006 audi a3 special edition.how do I enable the dash display and outside temp display.i have fitted a new temp sensor but still no display.can it be activated through vcds and do I need any extra parts thanks.
    May 2012
    RETFORD, NOTTS
    1,753
    Did you get a cable? If not give me a bell I'll pop over and sort you out.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    harvz's Avatar
    Dec 2011
    60
    Quote Originally Posted by @udi A3 View Post
    Yh if u have a midline steering module u can enable outs temp and dis. @udi A3 will sort your coding he did mine top job. just buy a new wiper stalk with dis controls and a new indicator stalk with cruise control (as u might aswell add it if u changing the other stalk) parts cost me 50 off eBay from scrapped cars and I cut out my own lower cowling. If u need a new steering ecu they are 30 from breakers and if u buy a highline one u can add mfsw which will cost u a few Bob to add. I never done this so can't say price.
    Very easy to fit will take u an hour or 2 if u never done before.
    Plenty of guides on asn which show pics step by step. So get googling and ebaying and call @udi a3 to enable it all he knows what he's doing
    May 2012
    RETFORD, NOTTS
    1,753
    Ambient Temperature Display
    That's the guide we used for harvz car iirc
    Apr 2013
    mansfield
    87
    how can I find out which module is on the car?
    May 2012
    RETFORD, NOTTS
    1,753
    Scanning with vcds?
    Nov 2008
    389
    Are you like me (also listed in that referenced post) - I.e you have a special edition rather than an actual 'SE'.
    If so you maybe have no DIS at all? Just different icons that light up in the dash?
    Can you take a picture of your dash clocks and your heater/ climate unit?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Apr 2013
    mansfield
    87
    Quote Originally Posted by phil_w View Post
    will get a picture up.
    Apr 2013
    mansfield
    87
    Apr 2013
    mansfield
    87
    find attatched picture
    Nov 2008
    389
    Yep same as my old A3- lowline clocks so no DIS of any kind. No amount of new wiper stalks can do anything about it. BUT as long as you have an AC button on your heaters / blower control you can enable the Temp and beeping/ snowflake symbol when dropping below 5 degrees. It's just an adaption channel but will need VCDS to do it. Ill try and find the old post with the details in.
    Apr 2013
    mansfield
    87
    doesn't have aircon
    Nov 2008
    389
    I know it doesn't have full climate but my special edition (a few extras over standard) not SE - had an AC button with standard heaters
    Nov 2008
    389
    And this was key to the success of the mod iirc
    Nov 2008
    389
    This was the original thread - ignore the end bit about changing wiper stalk - its the first bit about the adaption channel - Ambient Temperature Display
  1. Dash Display
    By macattax in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th April 2007, 15:58
  2. Replies: 0
    Last Post: 25th January 2007, 19:50
  3. dash display/wheel control
    By khalil in forum In-Car Entertainment
    Last Post: 17th July 2006, 19:43
  4. IN DASH DISPLAY INFO. HELP!!!
    By MAXGAVIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2005, 03:22
  5. Alpine link to dash display?
    By medicineman in forum In-Car Entertainment
    Last Post: 13th February 2005, 16:29
