JMB RetrofitsChris Nott
Results 1 to 10 of 10
    37
    37's Avatar
    May 2013
    Area 51
    118
    Slight vibration from rear - Only between 60-70MPH
    Hi guys,
    I recently purcahse an 07 Audi A3 SE which has 2 weeks old MOT as well. Everything is good apart from one little niggle. There is a slight vibration (I do mean slight but noticeable) between 60-70 MPH. There isn't anything @ 80. One thing is though that rear tyres have only got about 3MM of tread left.
    Could it be bcause of that or balancing or the bushes ? Any ideas ?
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    I get something very similar on my 2007 A3 at around 60-65 mph. It's so slight it's hardly there at all. Thinking it probably requires wheels balancing. It's maybe only slightly biased towards the rear.
    After 3 BMWs in over 13 years, I'm giving Audi a go.
    dan77's Avatar
    dan77
    Dec 2008
    Down south,
    195
    is it a quattro? if so check this
    AUDI A3 Quattro VIBRATION NOISE HELP
    A3 1.8T sport, revo stage 1, Forge 007, Green cotton panel filter, TTpedals. . . . . SOLD
    Golf GTTDI 130 . . . . . SOLD
    Current 2006 A3 2.0TDI Quattro S-Line, Revo stage one, chrome pedals, black grill, full interior and number plate LEDs retro fitted cruise control,
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Quote Originally Posted by dan77 View Post
    Mines front wheel drive.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Wheel balance or slight buckle are my first things to look for. At tyre centre they will be able to check both.
    37
    37's Avatar
    May 2013
    Area 51
    118
    Thanks for the quick replies chaps. Appreciate it. dan77, it's not a Quattro. BoutTime/MrLapou, I have a feeling it requires balancing.
    BoutTime - Have you had the problem for a while?
    BoutTime's Avatar
    Apr 2013
    Trowbridge
    91
    Only had the car a couple of weeks. Previous owner was a friend's Dad. He only averaged about 3800 miles a year for the 6 years he had it. In fact he just had the tyres replaced for the first time as the original fits very perished. And they had plenty of tread left too. So probably is wheel balancing. Cam belt and water pump replaced too!
    37
    37's Avatar
    May 2013
    Area 51
    118
    Thanks for that info BoutTime. I thought changing currently worn tyre with a part worn and getting it balanced might work, but it hasn't. The reason I am reluctant in changing tyres to brand new ones is because I want to change the alloys since my current ones are bad :P - If you get around solving your problem before mine, do let me know.
    Ultra Violent's Avatar
    Sick & Wrong.
    Feb 2013
    North o' the Border.
    1,034
    Hi folks,
    I've just been through exactly the same thing with my A3 Quattro.
    Had it in the garage a few times and they couldn't find out what the problem was, so got it sent to Wearside Audi
    they diagnosed the propshaft, thankfully it's under warranty so they ordered a new propshaft and fitted it in a couple off days.
    Long story short, problem completely gone, like a new car again, also while it was in the garage the first time they fitted a new Turbo because they thought that was causing the problem originally,
    so new propshaft and Turbo, and back to enjoying the motor again.
    Hope that helps.
    " Just because your paranoid, Don't mean their not after you " - Nevermind.
    37
    37's Avatar
    May 2013
    Area 51
    118
    Cheers mate. Mine isn't a quattro. But mine is probably down to a wonky alloy.
  1. vibration from rear on full lock 2001 s3 help!
    By fezzers in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th January 2012, 20:07
  2. Replies: 10
    Last Post: 25th July 2011, 20:45
  3. slight leak from rear of gearbox
    By bowwow2uk in forum RS6 Forum
    Last Post: 5th September 2010, 11:29
  4. Massive vibration from rear
    By Sanj in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th August 2010, 23:37
  5. Slight rattle from rear seatbelt feed
    By jbreedon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 22nd April 2006, 22:09
Tags for this Thread
