Chris NottSky Insurance
Results 1 to 9 of 9
    Oct 2012
    Warrington, North West
    986
    Help/advice on changing aux belt?
    I noticed mine is a little perished were done of the grooves have came off in a patch sort if thing.
    I'm going to give it a go myself, is there anything else I should be changing at the same time whilst its off?
    Should I get it from audi or will a contitech one be fine from ECP?
    Oct 2012
    70
    Not much else to think about changing and it should be a pretty straightforward job. Contitech's good stuff so ECP is fine or CarParts4Less do the same parts for even cheaper. You'd pay a fair bit more at the dealers for the same quality item.
    Oct 2012
    986
    So I don't need to be changing no pulleys etc?
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    You'd better change the belt tensioner and alternator pulley too.
    When I did mine I only changed the tensioner. Now I have to change it again because the alternator pulley got stuck and forced the belt to press harder on the tensioner. It gave up again.
    Pay once and stay relaxed. Don't be cheap because you may end up paying more in the end.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    336
    How difficult are these to change? Do you just release tension by pushing back on the tensioner, slip the belt off and a new one on?
    Oct 2012
    986
    Quote Originally Posted by elrao View Post
    From what I can gather pretty much, I think you can lock the tensioner with a drill bit?
    27,083
    Its allot easier with 2 people, takes a few minutes usually, just use a iirc 17mm spanner on the raised lug on the top of tensioner, push it the way that loosens the belt, pop old one of, put new one on & get it under tensioner, then slowly move spanner so tensions back on, check with torch all in grooves ok, run it up & inspect, voila.
    bmh.01's Avatar
    Apr 2012
    Nuneaton
    279
    What engine? When was the cambelt and tensioners last changed?
    Oct 2012
    986
    Cambelt was done just before I bought it August last year, and its a 2.0 tdi bkd
  1. RNS-E = AUX or LINE IN help/advice/wisdom needed.
    By kevin00 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2013, 17:27
  2. Changing aux belt tensioner alternator pulley
    By choimaloy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2012, 23:09
  3. What to remove to change aux belt and tensioner
    By adidasandy in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th February 2012, 18:07
  4. Help please - aux belt tensioner
    By Ian_83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th March 2011, 18:56
  5. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
