Volks AutosAH Fabrications
Results 1 to 12 of 12
    Apr 2013
    40
    Glovebox ipod connecter help?
    image.jpg Okay so i put the ipod into this put it falls out wen driving and it doesent even work anyways do i need a cable or anything??
    27,121
    Does the connector line up ok & assume you're pressing cd on head unit to play?
    Apr 2013
    40
    It goes in but is fairly loose wen i accelerate or brake it falls out and yes pressing cd tried every button nothing happens
    Jun 2011
    138
    "do you need a cable" you mean the one that connects the ipod to back of the headunit? YES
    Audi S3 2.0TFSI.. Milltek Turbo-Back Non-Res, ITG maxogen, THS FMIC, HPFP internals, Custom FR&RTuning dyno Software
    Previous
    Audi S3 1.8T with the following mods: Milltek Cat Back Non Res exhaust, with THS Decat, Induction kit , Forge 007P Valve and Custom FR-RTuning Stage 2 Software..
    Apr 2013
    40
    I mean like put one end of cable into the ipod then plug that onto the connector in glovebox
    Jun 2011
    138
    and the connector in the glovebox is connected to the back of the deck?
    Previous
    Nov 2008
    389
    Regards the falling out bit - from the factory different little plastic adapters came in a bag that were to add pressure fit to different models of iPod - you've got one inserted in the front of the photo which is probably for a thicker, older model.
    Could just be faulty unit for the other issue, or no connection from the rear to headunit but I'm sure that would be peculiar...
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Nov 2008
    389
    Forgot to ask what iPod you are plugging in?
    Apr 2013
    40
    Yea back of the deck and its the old ipod video
    Nov 2008
    389
    Ipod video should be fine - it's the newer ones that can't be charged etc with that style of iPod adapter
    Nov 2008
    389
    Difficulty is that when its in the slot you can't see the screen to tell if the iPod is doing anything. A successfull plug-in results in the audi logo appearing on the iPod screen. An iPod extension cable would be the way to check that out but sounds to me like a duff audi iPod prep
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    Get an iPod extension cable off eBay for next to nothing, that's what I had when I had that iPod connection before I changed it to AMI. Make sure it passes audio though as there are lots of data only ones on eBay.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
  1. Ipod and sat-nav connection help.
    By qawsed in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th January 2010, 15:14
  2. ipod connection help
    By Matt in forum In-Car Entertainment
    Last Post: 15th May 2009, 17:24
  3. Glovebox Ipod help
    By amcg1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th March 2009, 08:34
  4. Ipod connection for MMI Navi Plus?!?!? HELP PLEASE PEOPLE
    By fatboytex in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2009, 18:04
  5. help please on ipod connection
    By beerglass in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th January 2007, 10:10
