AH FabricationsBadger5
    Apr 2013
    35
    knock/rattle/vibro under load / on acceleration (8P S3)
    any ideas what this could be
    it is a rattle/knock sound coming from underneath the front of the car, seems more towards the passengers side (NSF)
    along the lines of, driveshaft, CV, profshaft, or something related.
    this is more noticeable under 50%+ acceleration, if driven carefully, cannot notice it at all
    as the speed gets greater, it turns into more of a wobble/vibration, but at lower speeds it sounds like a knocking, bit like a knackered CV, but im not so sure its that!
    have had a brief look on a ramp without removing anything, and all appears to be ok.
    would like to know if anybody else has a similar issue, or has had one in the past, and to see what resolutions there are/were.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    DMF failure?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Apr 2013
    35
    i am not so sure on that one, i think it is suspension or drive related, but not the flywheel. however cant rule it out (although there is history that it was replaced not too long ago on my car, so would hope it is not that part again?)
    Apr 2013
    35
    my car is a 2009 sportback.
    the garage is suggesting it may be a damaged/bent prop
    does anyone know where i can get one from? are they the same for 3dr and 5dr?
    any ideas on part number, and/or prices? or anyone breaking an 8P S3?
    thank you in advance!
    Apr 2013
    35
    turns out it may just be the front rubber (front prop donut i think?)
    but this still means replacement prop
    Apr 2013
    35
    replaced the whole propshaft and both end bushes with brand new items (at great expense! )
    the old bush was worn, and the centre bearing was damaged on one side, where i had been using the car with the vibration and got worse due to the worn bushes.
    decided it was just best to replace the whole lot
    the car is now fixed, and drives so nice, glad to have that out of the way
  1. Vibration / Knocking Under Load from centre/rear of car - Quattro
    By AlexGSi2000 in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd December 2012, 15:06
  2. Knocking under load
    By mememe in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2011, 16:33
  3. Annoying rattle/tapping under acceleration
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2010, 11:04
  4. Power loss under load (TDi 130)
    By smo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2008, 14:03
  5. 1999 S4 - gearbox clunking under load... :(
    By brixo in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th May 2006, 12:33
