    Oct 2012
    120
    MFSW with DSG and GSM Kit
    Hi Guys,
    I've read that a MFSW will be a straight swap for those with DSG. I have a 2005 DSG....
    However what I want to know mainly know, is will the phone function on the wheel work when I have the GSM kit that does allow bluetooth connection?
    Thanks,
    Granty
    Fossie
    Rhubarb Triangle
    3,969
    AFAIK phone function only works with OEM Bluetooth module fitted and coded properly.
    Don't know what GSM kit is so couldn't comment but would maybe need rewiring ?
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Oct 2012
    120
    Thanks.
    It's the dash mounted cradle which has bluetooth built in.
    Everything comes up on the DIS already including contacts but as it stands I have no way to interface using the vehicle. I have to use the phone manually....so a MFSW would solve this
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,108
    If you have the oem Bluetooth which by your description you do, then yes mate, the MFSW will work with your phonebook.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
  1. Various Flat Bottomed MFSW with and without airbags
    By s8craig in forum For Sale/Wanted - Audi Parts
    Last Post: 14th December 2011, 10:27
  2. 2005 A4 with Bluetooth and MFSW question - coding problem?
    By Fireyjack in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th January 2011, 15:58
  3. Replies: 0
    Last Post: 21st November 2010, 19:33
  4. Audi GSM prep with Bluetooth and NO MF steering wheel.
    By dik in forum In-Car Entertainment
    Last Post: 23rd April 2006, 22:44
  5. for those with DSG and Tdi power
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2005, 08:26
