Badger5EM Tuning
Results 1 to 15 of 15
    Aug 2012
    68
    Standard Wheel Bolts Not Long Enough For O.Z Superleggera? (Pics)
    I have tried fitting a set of O.Z Superleggera to my a3 but the standard wheel bolts are not long enough I think the Offset is 45 and the Stud pattern is 112?shepway2013050100394.jpgshepway2013050100396.jpg
    TDI140's Avatar
    May 2011
    1,349
    Offset should be in the back of every wheel mate offset must be wayyy off for the bolts not to fit as ive had about 4 sets of wheels and now running bentleys and used same standard bolts for all of them
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    336
    It's the physical depth of the centre of the wheel. I had a set of wheels before where I had to use longer bolts because of this (was years ago - can't remember make!) even though they were the same size otherwise (same offset, width etc).
    You need a minimum of 7 turns into the hub, every turn after that doesn't add much (will dig out the science that backs this up!). So with a 1.5mm pitch you need about a 10.5mm of thread + the thickness of your brake disc. I think standard wheel bolts usually allow about 17-18mm.
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    I have BBS CH for the summer. 5x112, et 50. I had to buy longer bolts as the standard ones were too short. Only 3 turns until they were tight.
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
    Feb 2013
    32
    My BBS wheels needed longer bolts too.
    Those though look ok, looks like you can see 7 threads on the bolts so I'd be happy with that.
    336
    Quote Originally Posted by fireheed View Post
    Need to see 7 threads after they've been through the brake disc!
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    My BBS CK's are ET44 and have the extended BBS bolts so you'll definately need longer bolts as the original ET is 56 I think. You don't want to chance it with those original bolts not being in safety.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    Aug 2012
    68
    I think I need 14MM X 1.5 60 degree tapered bolts im not sure if they have to be a certain type of seating either taper or radius.
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Thread = M14x1.5
    Seat = Radius
    Head = 17mm
    ...is what is needed for standard wheels. Not sure if they'll be the same?
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    336
    OEM wheels are usually radius and aftermarket are often tapered, but best check with the wheel manufacturer if in doubt.
    Aug 2012
    68
    Spoke to the person I bought them from and he said the bolts he used on his golf are 1 inch longer than standard? is that a 52mm total bolt length needed then? I definitely wont chance it with the standard bolts! I cant even get them in on the fronts, I trying to find some decent quality bolts, here's a pic of the bolt length on my other alloys:
    Mar 2013
    38
    You need to buy new bolts.. in tirerack USA always i buy rims it came with the new bolts
    336
    Quote Originally Posted by swift View Post
    You need to be very careful if the bolts are too long as they will bottom out in the hub and of you try to keep tightening them then you'll end up stripping something and need it re-tapping. This is a voice of experience!!
    Jul 2012
    Singapore
    9
    Same as for my Ultralegerra's-frightening thing was I only found out about it AFTER a track session....
    So, it's one of 2 things-3 turns is good enough or I'm just very lucky. I think the latter...Changed to bolts about 5mm longer than stock....
    Quote Originally Posted by Johnny Bravo View Post
    Aug 2012
    68
    I'm a bit confused because my standard radius bolts seem to fit so not sure if I should be buying radius or a 60 Degree Taper that are meant for Aftermarket Alloy Wheels?
  1. spacers with standard wheel bolts?
    By crazypainter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2011, 19:40
  2. Extra long Wheel Bolts for 20mm spacers
    By bhavin1986 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2011, 00:27
  3. S3 not low enough at front for you?
    By Khufu in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2009, 18:55
  4. Extra long locking wheel bolts.
    By devonmikeyboy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2009, 12:10
  5. WHEEL BOLTS FOR SPACERS
    By S3 03 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd September 2006, 22:21
