Chris NottEM Tuning
Results 1 to 18 of 18
    Jan 2011
    226
    Can you run xenons...
    Without the headlight washer and leveler system?
    And then for MOT's just take the headlights off and fit the normal ones?
    I am looking at an a3 it has full spec except no xenons.
    Alternativly has the HID issue been fixed yet and if so where can I buy some projector headlights that I can fit them to ?
    All the ones I have found, from say FK tuning are chavvy or have DRL's inside that do not look standard.
    2008 A3 1.8t FSI Sportback S-Line - Avus Silver - Full spec.
    Mar 2012
    369
    Of course you can - but ask yourself why that stuff is fitted and required by law on all new cars with HID lights.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    As said, this is possible.
    Friend of mine did it, lowering the xenons right down in order to reduce the flash/glare to other drivers and seemed to work fine. Though still illegal and not recommended, obviously.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    TDI140's Avatar
    May 2011
    1,364
    Im doing it lol everything seems fine ive got MOT in june but the guy said it seems fine
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Double J's Avatar
    Jun 2012
    London
    49
    As long as the beam pattern is set correctly it shouldn't be an issue.
    Better than HIDs in reflector housing at any rate...
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    It's certainly possible but might be a lot of hassle.
    My car was registered in Germany for a time and I had to change my headlights for continental ones. Instead of forking out for bi-xenons I fitted halogens. To do this I had to rewire the headlight connector and recode them on VCDS.
    It's not a major job but going back and forth to pass and MOT might be a bit of a pain. I think I'd prefer to just fit top end halogen bulbs.
    8P2 S3
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Yeah true, but it's the glare that's the killer...
    Quote Originally Posted by Double J View Post
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    I would of thought it would be fine.
    I'm pretty sure they aren't required for an mot but are required to work only if fitted.
    There are cars on the market that run xenon and don't have washers or levellers as standard.
    Jan 2011
    226
    Its fitting the washers that is the expensive part :/
    notta3's Avatar
    Jan 2013
    23
    so how would you set the beam pattern correctly? I was under the impression you needed auto levellers and washers as a legal requirement? but I too have seen cars with xenons but no washers etc...
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Quote Originally Posted by notta3 View Post
    Use a beam setter all MOT Stations have them or body repair shops maybe even your average mechanic will have one.......
    I've spoken to a friend if a friend about the washers and levellers and he said that if there fitted they must work. Rear window wipers are similar sort of crack. If there attached they need to work of there not...... They they can't fail them.
    notta3's Avatar
    Jan 2013
    23
    Quote Originally Posted by Jack_tdi View Post
    thanks for the advice.
    As for the legality issue, I was under the impression that although they would pass the MOT they still wouldnt be road legal. Can anyone clarify or point to any documentation? Ive had a bit of a google and cant bring anything up.
    Mar 2012
    369
    Not any more - there were a very few in the past but current construction and use regs for new cars require them and have done for some time.
    As for MOT - here are the rules - of course you can ignore them or change 'em and then change 'em back - I guess it's a question of whether you care about actually being legal or just what you can get away with. Given the amount of illegal mods I see every day, you must be in with a good chance if all you want is to get away with.
    http://www.partinfo.co.uk/files/MOT%...20Lighting.pdf
    "Dazzle can also be caused if the lamps are dirty or aimed too high due to, for example, carrying
    rear seat passengers and/or heavy items in the boot. Vehicles with HID headlamps are therefore
    required to have a headlamp washing system (a wiper is not required) and be self levelling, which
    may be achieved either by the use of either headlamp or suspension levelling systems.
    The presence and operation of these headlamp cleaning and levelling devices has been
    added to the test. Therefore, if a mandatory headlamp levelling or cleaning device is missing,
    inoperative or otherwise obviously defective, the vehicle will fail.
    This raises the question of whether these checks apply to vehicles fitted with after-market HID
    lighting kits. These kits convert conventional halogen headlamps to HID Xenon and they are
    widely sold and fitted to vehicles used on the road. The Department for Transport considers
    that after-market systems should be required to meet the same safety standards as that applied
    in respect of these lamps at vehicle Type Approval. Therefore, in order to pass the MOT
    test, vehicles fitted with after-market HID systems would also need to be fitted with headlamp
    cleaning and self-levelling systems.
    Some high specification estate cars are fitted with a selflevelling suspension system and this would be considered as adequate for the purpose."
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    Quote Originally Posted by JohnE View Post
    in respect of these lamps at vehicle Type Approval.[B] Therefore, in order to pass the MOT
    test."[/I]
    So all the vehicles with xenon and no washer / levellers are to fail an mot........
    Mar 2012
    369
    Well, according to VOSA, yes. However, as we all know, not every tester is 100% up to date at all times, and those folk who want to get away with it will probably be able to. I'm amazed at how little interest in cars some MOT testers have. I took my old Mondeo (which had had fully legal factory HID/xenons with washers and levelling) for MOT once and the guy checking the beam aim asked me to move the thumbwheel thingy to change the beam height - I explained the levelling was automatic and therefore there was no thumbwheel and he was genuinely surprised and I could tell he doubted my word.
    Given that the people who want to fit HIDs without going to the bother of doing it properly won't complain if a tester passes it, there's not going to be a lot of comeback on any tester who ignores the VOSA rules.
    By the way - as I said at the start - why do you think levellers and washers are required by law for new vehicles?
    Jan 2011
    226
    This is why my plan was come MOT time to simply swap the headlights over.
    notta3's Avatar
    Jan 2013
    23
    Quote Originally Posted by thesmileyone View Post
    I was thinking about doing this too, however I think its not just bumper off and swap the lights/adaptor over. Do you not need to run a wire to the CEM to get high beam working? Sounds like alot of work! or maybe I'm just being lazy!
    Mar 2011
    141
    Only if your headlights has "DC / DCR" mark & the HID you are using is below 2000 Lumen.
    Otherwise you will need to install the headlight washer and leveler system.
  1. Can you run different width (225 & 235) tyres on an A3 Quattro?
    By MG in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th March 2013, 13:17
  2. After Run Pump - Can You Set How Long it Runs For? (Battery Died)
    By fran-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2011, 11:06
  3. how can you tell the difference between xenon and bi-xenon headlights.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st October 2010, 00:16
  4. How can you tell the difference by looking at xenons ? bi xenons ?
    By tdi-man in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2010, 14:04
  5. where can you post cars for sale?
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th January 2003, 18:30
