EM TuningBadger5
    Feb 2013
    75
    Loose bumper and wheel arch! :(
    Howdy All,
    Had some radiator issues this weekend that involved removal of the front bumper to resolve.
    When refitting everything i found a large amount of fixings were damaged/worn, namely the 2cm long fixings that the torx screws fit in.
    So i now have loose wheel arches and a loose bumper!
    Any idea where i can get these from??
    Bonus Question 1,
    How should the radiator be fixed to my car? Where are the screw points?
    My radiator is leaning into the engine bay at the moment (temporarily fixed with cable ties)..
    Bonus Question 2,
    What fixings go into the top of the bumper (3 bolts?) as mine have sheared off!
    Feb 2013
    75
    Can anyone shed some light on this for me?
    If it helps, i have a 2005 2.0TDI Sportback
    Apr 2013
    Aberdeenshire
    595
    Quote Originally Posted by revilo View Post
    I replaced the radiator on my 3.2 you have to remove the front bumper then disconnect lights crash sensors etc then remove the cross member (4 bolts) the radiator sits in a sub assembly on rubber bushes and held in by Torx screws from the front the hoses are secured with clips.
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    944
    You will have to buy new fittings. Are you on about the line where the bumper and wing meets? There is a fitting there that you can pop out and replace.
    Feb 2013
    75
    Quote Originally Posted by Ironborn View Post
    Yes i believe so! Any idea what part number this could be?
    I think i also need the expanding nuts for the screws, if you have any ideas where i can get these?
    Feb 2013
    75
    Just found out that you can grab these from Audi for about 80p each! That was easy enough
  1. New S3 with pics and front arch wheel gap
    By mojo555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd April 2012, 10:07
  2. Replies: 2
    Last Post: 4th April 2010, 20:28
  3. Part number and price for wheel arch trim
    By razza1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd February 2010, 21:14
  4. Cabriolet rear bumper trim and wheel offsets!
    By markyzs180 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th April 2009, 23:15
  5. S3 bumper and exhaust on an simple A3
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2003, 09:07
