Chris NottVolks Autos
    Mar 2013
    52
    Coding For A3 Sportback Led Rear Lights Retrofit
    hello there got a genuine rear led lights 2009 to fit my audi a3 sportback 2005 and adapters just not sure about how lights coding works any help will be appreciate cheers
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    You'll need to use vcds to code the lights in, there's a guide in the thread here...
    2010/2011 LED Rear lamp for Sportback coding using Kufatec device.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Mar 2013
    52
    don't understand nothing im so stupid
    Johnny Bravo's Avatar
    6+1 Gears
    Jun 2009
    Romania
    797
    You need a VCDS cable. The coding is this:
    central electronics
    coding
    help with long coding
    Btye 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - Fog lamps as a taillight
    Byte 12 to Dec = 36 - dimming rear standlight
    Byte 19 Bit 2 Cold Diagnosis rear active - this must be activated
    DSG | Vienna Leather | Bose Sound | MFSW | Interior Lights Pack | Light & Rain Sensors | Auto Dimming Mirror Mods: LED RNS-e | FL LED Tail Lights | Bi-Xenons | Illuminated Speaker Grilles | Tinted windows | Chrome Switches | Chrome Paddles&Commands | RS4 Start Button | Cruise Control | S3 Pedals | S3 Roof Spoiler | 18" BBS CH | H&R Spacers 10/15 mm | Bilstein B16 PSS10 | H&R 26/24 ARBs | TT Arms | S3 Front Brakes+DS2500+Tarox F2000 | HEL Brake Lines | VNT20 | EGR&Cooler Delete | Custom Remap
  1. Sportback LED Rear Lights (Fitted by itwasntme187)
    By chrisb72 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2014, 18:14
  2. Coding For A3 Sportback Led Rear Lights Retrofit
    By Stampie in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th September 2011, 20:56
  3. Sportback LED Rear Lights
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th November 2009, 19:37
  4. A4 Coding for A3 Sportback Rear Lights
    By aristides in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2009, 22:16
