hello there got a genuine rear led lights 2009 to fit my audi a3 sportback 2005 and adapters just not sure about how lights coding works any help will be appreciate cheers
You need a VCDS cable. The coding is this:
central electronics
coding
help with long coding
Btye 9 to Dec = 0 - as the final brake light
Byte 10 to Dec = 0 - Fog lamps as a taillight
Byte 12 to Dec = 36 - dimming rear standlight
Byte 19 Bit 2 Cold Diagnosis rear active - this must be activated
central electronics
coding
Thread revival. I did this and yes my LEDs are working fine, and the fogs are working. But reverse lights are not working. Any reason why this would happen? Cheers
Hmmm... they should work if they are properly coded. and the ones on the boot lid do not require adapters.
Have you connected the extra wire on the boot lid lights?
