Monster MotorsportChris Nott
    Apr 2013
    Fault code 17903 please help!!
    Hi,
    I have an Audi A3 1.9 tdi sport 2004 and would like someone to shed some light on fault 17903.
    I have today changed the egr cooler, egr cooler control value and solenoid, as codes showed faults will all three, I deleted all faults and all cleared apart from this one 17903. I was on the understanding that this is the cooler control value??
    All fuses have been checked too.
    any advice would be greatly appreciated as I just want to get the engine management light off!!
    Many thanks in advance
    Claire
    Smillie13's Avatar
    Sep 2012
    West Lothian
    933
    Follow Smillie13 On Twitter
    Are you sure that's the right code ??
    Here for a good time, not a long time
    x Susan x
    Apr 2013
    Hi, smillie13.
    Yes it's the correct code search online last night and found audi codes via German website and said cooler control value short or to close to ground don't really understand what that means but said to check control module and wiring.
    Claire
    Apr 2013
    The vag code is p1495, actually says switch over value for egr cooler (n345) open or short to ground not what I put just now.
  1. Replies: 9
    Last Post: 7th February 2012, 18:20
  2. Fault code p0030 , p0130. help
    By kek700 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2010, 20:20
  3. 9 faults found. Codes inside...Please help!!!
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st February 2010, 15:12
  4. 8 Fault codes, not good Help!
    By locker in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2008, 23:00
  5. Can anyone tell me what these fault codes are please?
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd July 2006, 13:16
