Results 1 to 15 of 15
    Apr 2013
    mansfield
    87
    a3 2.0 tdi 2006 loss of power white smoke.
    could somebody give me some advice my 06 a3 2.0 tdi seem to give out white smoke some of the time takes ages to get up to temperature.when driving it seems to go a bit then lags then goes again.havent noticed it losing water.read on internet it could be egr cooler or egr valve or oil cooler anti judder valve or even the head gasket any help would be appreciated so I can narrow it down a bit thanks.
    Yiddogaz's Avatar
    Nov 2012
    Tyne and Wear
    31
    White smoke is normally water getting into the combustion chamber but someone with a bit more knowledge will be able to help you diagnose it properly.
    The loss of power makes me think turbo!
    Apr 2013
    mansfield
    87
    it goes ok just like theres a big flat spot
    TDI140's Avatar
    May 2011
    1,348
    My car threw out white smoke yesterday after turbo popped
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Apr 2013
    mansfield
    87
    how will I check turbo whats the symptoms?
    Apr 2013
    mansfield
    87
    Any more advice or some checks I can do before it goes to garage?
    TDI140's Avatar
    May 2011
    1,348
    Mine didnt even make the police siren noise it just went within second of changing the intake pipe boot that connects onto the turbo compressor housing as mine was knackered and as soon as i changed it for the new one my turbo blew up at 1500 revs just went bang
    TDI140's Avatar
    May 2011
    1,348
    image.jpgNew ones the one on the right
    Apr 2013
    mansfield
    87
    Checked all the hoses to and from the intercooler.
    TDI140's Avatar
    May 2011
    1,348
    What about the ones connected onto the actual turbo housing ? As the one in my picture is the boot that comes onto the turbo intake compressor housing
    Apr 2013
    mansfield
    87
    Where are these located?
    only checked the rubber hoses from the intercooler.
    now you mention it I have heard a a loud hissing sound when revving the engine.
    Double J's Avatar
    Jun 2012
    London
    49
    How did you know your pipe was knackered buddy?
    TDI140's Avatar
    May 2011
    1,348
    Had it boost leak checked and was pouring out with smoke right from that hose
    TDI140's Avatar
    May 2011
    1,348
    I knew it was knackered due to having a dump valve noise which was odd on a tdi and also boost gauge was dropping pressure when accelerating
    Double J's Avatar
    Jun 2012
    London
    49
    Quote Originally Posted by TDI140 View Post
    Thanks buddy. I think I've got a bit of that on mine so I'll check it out.
  1. Help my a3 2.0 tdi 140 loss of power
    By Lukebry88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th February 2013, 06:14
  2. 2.5 tdi Quattro loss of power
    By Jonny C in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th December 2011, 09:14
  3. Audi A6 2.5 tdi 1998 Loss of power
    By Beez in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 5th April 2010, 22:54
  4. TDi engine loss of power :-(
    By APL TDi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th September 2009, 14:08
  5. Audi 80 1.9 TDi - intermittent loss of power
    By horlix in forum Diesel forum
    Last Post: 2nd May 2006, 22:07
