Aftermarket sub help??
tr1ck
Cornwall
Basically I have an aftermarket sub and amp kicking around.
I have the double din audi concert head unit which I take it has a small audi sub in the side panel in the boot, has anyone or does anyone know if you can run an aftermarket sub off the standard wiring or amp?
standard wiring would possibly be to thin to handle power (if its a more powerful sub/amp)
i have the concert single din, and already have the audi sub in car, and i wanted to have a more powerful sub and amp package but iv been told i cant without adding a few other harnesses
You can use RCA high low adapters off the aftermarket sub and the remote cable too. Only think you'll need to run is a power cable from the battery to the boot
