Chris NottSky Insurance
Results 1 to 8 of 8
    Dec 2012
    S3 Clunking/Knocking noise coming from front end even after changing drop links!!
    iv got a 2008 s3 that was lowered before i bought it. not sure on what but recently ive had a clunking/knocking noise coming from the front left of the car which after a bit of research changed the drop links. the noise is still there and is getting worse! the smallest bump and im getting noises and its driving me insane!! any ideas guys would be much appreciated!
    Oct 2012
    64
    Anti roll bar bushes maybe? They'll knock when you hit bumps if the rubber (or poly, depends what you've got fitted) bushes are worn.
    Dec 2012
    im not sure, the car went into audi for a mot 2 weeks ago and i did mention it but they said theres nothing wrong. it even went for a service lat week and again not a peep!
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    i would take a guess at ARB bushes also. Took mine into the garage 4 weeks ago for them to investigate a knocking noise i had on the front which i was only experiencing when going over pot holes. Took it for a road test and it didn't knock at all - no potholes. They then got it up on the ramp and couldn't really find anything obvious except for some very minor play in one of the ARB bushes.
    So i booked it in to have these bushes replaced and when they took the old ones off they both had massive holes in them
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    JPK
    May 2012
    278
    Will likely be subframe shifting, fixed with tyrolsport deadset subframe kit. Or worn strut mounts.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    davc's Avatar
    Foursprung Duck Technik
    Jan 2013
    Caledonia
    214
    I've got the dreaded clunk over uneven surfaces as well and it's doing my head in. The arb bushes are fine so I'm going to try new top mounts and bearings.
    If this doesn't fix it is the Tyrolsport Deadset kit available in the UK, or do I need to order it from the US?
    MY'09 S3 Sportback |Gloss Black Mirrors |Buckets |Black Optiks |Open Sky |Light & Rain Sensor Pack |CH/LH Lights |RNS-E & No Highs No Lows it must be Bose |
    JPK
    May 2012
    278
    Order from US but shipping is quick. I got mine in NZ within 2 weeks.
    davc's Avatar
    Jan 2013
    Caledonia
    214
    Thanks mate. Didn't realise you're in NZ! Awesome GTI in the UK stock the ECS Tuning Spacer kit @ just over £14 so I'll probably try that as a much cheaper alternative.
  1. Noise coming from front end of my A3 1.8T
    By SteveA31.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2011, 11:26
  2. Knocking noise coming from open sky sunroof?
    By Johnnyb in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th August 2010, 17:38
  3. Knocking noise coming from the back????
    By munchman s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2009, 17:04
  4. Hmm, droning noise coming from front....
    By dieselfitter251 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2009, 17:05
  5. Strange "cluncking" noise coming from front
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 13:10
