Steering Angle Sensor and Battery not holding charge - Any relation?
Tay
Active Member
Warrington
Just wondered if anyone has had a similar problem, the mrs was driving the S3 yesterday with no problems, parked it at home around 5pm. Went to start it today at 8, no luck the typical battery/starter motor combination of a clicking noise.
I was at work so could do nothing so have been left with the dilemma to fix now, scanned the car with VCDS, battery light was on but no fault linking to that, only fault code I had was for the Steering Angle Sensor having no basic settings. (Ill post the log once I get chance to go on my laptop).
So I jump started the car, no problems went for a 15 minute drive and seemed okay. Two hours later, need to go back out, back to square one! My only thoughts would be the battery at the moment, anyone got any suggestions?
Friday,26,April,2013,13:54:22:30197
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 77
VIN: WAUZZZ8P38A****** Mileage: 107040km/66511miles
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FNU04W
Coding: 01030003180F0060
Shop #: WSC 06314 000 00000
VCID: 377B6EE2463871A0D06
2 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 5
Mileage: 106615 km
Time Indication: 0
Date: 2013.04.19
Time: 20:09:38
Freeze Frame:
RPM: 836 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 31.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.970 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:36:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.287 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
VCID: 72ED9FF66DDAD488278
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 082921 Serial number: 8P0820043AH
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:35:41
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007178923
Coding: 918E0F07A03210004F0000000000000000084E175A060202000000000000
Shop #: WSC 06314 000 08192
VCID: 4587142A0CD4133052A
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 222
Mileage: 106994 km
Time Indication: 0
Date: 2013.04.22
Time: 20:30:00
Freeze Frame:
OFF
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 00:00:00
Freeze Frame:
OFF
Voltage: 9.40 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0G04L30
Coding: 0071612
VCID: 4D972C0AD4A4EB709AA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78F9ADDE0BA6BED819C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2244G001000602
Coding: 0005428
Shop #: WSC 00383 210 83674
VCID: 418F003A18FC3F106E2
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0752386A7
Coding: E9831F060006020101
VCID: 306955FEA356A69891C
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 366563E6413288A8CB0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G4FNU04W
Shop #: WSC 00481 210 88137
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H02 0040
Coding: 0000560
VCID: 43830A3202E02D007CE
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H10 0080
Coding: 18802020025849290505489AC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
00323 - Vehicle Inclination Sensor (G384)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000560
VCID: 4481092E07EE2A38454
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D777CCA64045BF00AA
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
Component: R Symphony2+ H16 0280
Revision: 00H16000 Serial number: AUZ1Z4G9068609
Coding: 0410101
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005147587
Coding: 0000122
VCID: 3E757BC6690240E8130
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 22: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 77: DTCs cleared
Chassis Type: 1K0
25-Immobilizer -- Status: OK 0000
Readiness: 0110 0101
Revision: 00H13001
Coding: 0021128
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:35:41
Freeze Frame:
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0000012
Coding: 0005428
Coding: 0000001
Coding: 0000560
1 Fault Found:
000 - -
Coding: 0000560
Coding: 0000012
Coding: 0410101
Coding: 0000122
Chassis Type: 1K0
08-Auto HVAC -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
1 Fault Found:
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:49:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 14.0°C
Voltage: 10.160 V
Revision: 00H13001
Coding: 0021128
Coding: 00062736
Shop #: WSC 06314
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:53:00
Freeze Frame:
OFF
Voltage: 8.35 V
OFF
ON
OFF
OFF
OFF
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0000012
Coding: 0005428
Coding: 0000001
Coding: 0000560
1 Fault Found:
000 - -
Coding: 0000560
Coding: 0000012
Coding: 0410101
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:54:29
Coding: 0000122
I'd get a new battery first
The steering angle sensor would have come up due to flat battery and may correct itself with a quick drive, or you may need to follow the wiki guide to reset it. Leave the wheel over for 30 seconds on the lock to lock procedure as sometimes it doesn't take first time round if your too quick!
Yeah that's what I was thinking to be honest, was debating whether to get the breakdown people out to check if my battery is dodgy. May as well make one call out for the years membership!
Yes the steering angle/warning light comes on with a flat/disconnected battery; it should clear after a short drive.
As for the battery sounds like a big drain or a dud battery. Check the alternator too is putting out about 14.4v with the engine running at the battery.
Thanks, well I've just gone and bought a battery after realising it has never been replaced so may have lost alll life now. Is this a specific channel in measuring blocks in VCDS so check alternator supply voltage?
Wouldn't bother. A battery place tested mine, claimed it was fine but my starting issues persisted. Replaced it anyway with Varta Silver bought online and all my problems vanished.
As another poster said to me, these cars require a stable and high quality power source. So get the Varta Silver.
All sorted now, Bosch Battery fitted the only one didn't seem to hold charge at all suddenly. Had to reset the basic setting for the steering angle sensor and then reset the calibration for steering limit stop aswell and power steering returned instantly :)
Cheers for the advice people.
Boon
having the same problem,what is wiki guide
Are you having problem with battery drain, or the steering angle sensor?
Hi bud,it's only started since my battery went flat,I fitted new Bosch battery tonight and still have power steering alarm.
Sounds like you need someone with VCDS to reset the steering angle & limits, it doesn't seem to 'learn' them itself
Simple job for someone who has a Ross-Tech lead & software
Just got the car back so far so good,they reset the code and told me the starter motor was bad so fitted a new one,also fitted new earth cable.starts on a button now :)
just hope the battery drain fault has gone.what sort of readings should I get AMPS when everthing is switched off
