JMB RetrofitsVolks Autos
Results 1 to 16 of 16
    Tay
    May 2012
    Warrington
    366
    Steering Angle Sensor and Battery not holding charge - Any relation?
    Just wondered if anyone has had a similar problem, the mrs was driving the S3 yesterday with no problems, parked it at home around 5pm. Went to start it today at 8, no luck the typical battery/starter motor combination of a clicking noise.
    I was at work so could do nothing so have been left with the dilemma to fix now, scanned the car with VCDS, battery light was on but no fault linking to that, only fault code I had was for the Steering Angle Sensor having no basic settings. (Ill post the log once I get chance to go on my laptop).
    So I jump started the car, no problems went for a 15 minute drive and seemed okay. Two hours later, need to go back out, back to square one! My only thoughts would be the battery at the moment, anyone got any suggestions?
    Tay
    May 2012
    Warrington
    366
    Friday,26,April,2013,13:54:22:30197
    VCDS Version: Release 11.11.5 (x64)
    Data version: 20121222
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 77
    VIN: WAUZZZ8P38A****** Mileage: 107040km/66511miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0050
    Revision: 5BH16--- Serial number: AUX7Z0G4FNU04W
    Coding: 01030003180F0060
    Shop #: WSC 06314 000 00000
    VCID: 377B6EE2463871A0D06
    2 Faults Found:
    001089 - EVAP Emission Control Sys
    P0441 - 002 - Incorrect Flow - MIL ON
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 0
    Fault Frequency: 5
    Mileage: 106615 km
    Time Indication: 0
    Date: 2013.04.19
    Time: 20:09:38
    Freeze Frame:
    RPM: 836 /min
    Load: 15.7 %
    Speed: 0.0 km/h
    Temperature: 79.0°C
    Temperature: 31.0°C
    Absolute Pres.: 1020.0 mbar
    Voltage: 13.970 V
    000406 - Engine Oil Temp. Sensor (G8)
    P0196 - 004 - Implausible Signal
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:36:44
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 9.0°C
    Temperature: 13.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 10.287 V
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
    Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
    Component: ESP 4MOTION MK60 0102
    Revision: 00H13001
    Coding: 0021128
    VCID: 72ED9FF66DDAD488278
    No fault code found.
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
    Component: KlimavollautomatH19 0420
    Revision: 082921 Serial number: 8P0820043AH
    1 Fault Found:
    01206 - Signal for Duration of Ignition Off Time
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:35:41
    Freeze Frame:
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007178923
    Coding: 918E0F07A03210004F0000000000000000084E175A06020200 0000000000
    Shop #: WSC 06314 000 08192
    VCID: 4587142A0CD4133052A
    Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    2 Faults Found:
    02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 222
    Mileage: 106994 km
    Time Indication: 0
    Date: 2013.04.22
    Time: 20:30:00
    Freeze Frame:
    OFF
    Voltage: 11.90 V
    OFF
    ON
    OFF
    OFF
    OFF
    02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 00:00:00
    Freeze Frame:
    OFF
    Voltage: 9.40 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
    Component: Airbag 9.41 H01 4230
    Revision: 91H01423 Serial number: 003CR0G04L30
    Coding: 0071612
    VCID: 4D972C0AD4A4EB709AA
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
    Component: J0527 036 0070
    Coding: 0000012
    VCID: 78F9ADDE0BA6BED819C
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
    Component: KOMBIINSTR. VDO H20 0640
    Revision: D0H20001 Serial number: 2244G001000602
    Coding: 0005428
    Shop #: WSC 00383 210 83674
    VCID: 418F003A18FC3F106E2
    Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
    Part No SW: 1K0 907 530 L HW: 1K0 907 951
    Component: J533__Gateway H15 0180
    Revision: H15 Serial number: 1400K0752386A7
    Coding: E9831F060006020101
    VCID: 306955FEA356A69891C
    Address 22: AWD Labels: 1K0-907-554.lbl
    Part No: 1K0 907 554 L
    Component: Haldex 4Motion 0116
    Coding: 0000001
    Shop #: WSC 00000 000 00000
    VCID: 366563E6413288A8CB0
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H20001 Serial number: AUX7Z0G4FNU04W
    Shop #: WSC 00481 210 88137
    1 Fault Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
    Component: Tuer-SG H02 0040
    Coding: 0000560
    VCID: 43830A3202E02D007CE
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.150 H08 1901
    Shop #: WSC 02069 000 90108
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 J
    Component: KSG H10 0080
    Coding: 18802020025849290505489AC637
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 907 719 C
    Component: Neigungssensor 005 0003
    Part No: 8P0 951 177
    Component: Innenraumueberw.H04 0020
    2 Faults Found:
    01135 - Interior Monitoring Sensors
    004 - No Signal/Communication - Intermittent
    00323 - Vehicle Inclination Sensor (G384)
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
    Coding: 0000560
    VCID: 4481092E07EE2A38454
    Address 55: Xenon Range Labels: 8P0-907-357.lbl
    Part No: 8P0 907 357 F
    Component: Dynamische LWR H02 0010
    Revision: 00000001 Serial number:
    Coding: 0000012
    VCID: 3D777CCA64045BF00AA
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
    Component: R Symphony2+ H16 0280
    Revision: 00H16000 Serial number: AUZ1Z4G9068609
    Coding: 0410101
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
    Component: FSE_255x BT H26 0340
    Revision: 00000000 Serial number: 00000005147587
    Coding: 0000122
    VCID: 3E757BC6690240E8130
    Address 01: DTCs cleared
    Address 03: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 19: DTCs cleared
    Address 22: DTCs cleared
    Address 25: DTCs cleared
    Address 42: DTCs cleared
    Address 44: DTCs cleared
    Address 46: DTCs cleared
    Address 52: DTCs cleared
    Address 55: DTCs cleared
    Address 56: DTCs cleared
    Address 77: DTCs cleared
    Chassis Type: 1K0
    25-Immobilizer -- Status: OK 0000
    Readiness: 0110 0101
    Revision: 00H13001
    Coding: 0021128
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:35:41
    Freeze Frame:
    Coding: 00062736
    Shop #: WSC 06314
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 222
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:48:00
    Freeze Frame:
    ON
    Voltage: 9.70 V
    ON
    ON
    OFF
    OFF
    OFF
    Coding: 0071612
    Coding: 0000012
    Coding: 0005428
    Coding: 0000001
    Coding: 0000560
    1 Fault Found:
    000 - -
    Coding: 0000560
    Coding: 0000012
    Coding: 0410101
    Coding: 0000122
    Chassis Type: 1K0
    08-Auto HVAC -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    1 Fault Found:
    P0196 - 004 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:49:06
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: 9.0°C
    Temperature: 14.0°C
    Voltage: 10.160 V
    Revision: 00H13001
    Coding: 0021128
    Coding: 00062736
    Shop #: WSC 06314
    3 Faults Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:53:00
    Freeze Frame:
    OFF
    Voltage: 8.35 V
    OFF
    ON
    OFF
    OFF
    OFF
    012 - Electrical Fault in Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:48:00
    Freeze Frame:
    ON
    Voltage: 9.70 V
    ON
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:48:00
    Freeze Frame:
    ON
    Voltage: 9.70 V
    ON
    ON
    OFF
    OFF
    OFF
    Coding: 0071612
    Coding: 0000012
    Coding: 0005428
    Coding: 0000001
    Coding: 0000560
    1 Fault Found:
    000 - -
    Coding: 0000560
    Coding: 0000012
    Coding: 0410101
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 7
    Mileage: 107046 km
    Time Indication: 0
    Date: 2013.04.26
    Time: 05:54:29
    Coding: 0000122
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    I'd get a new battery first
    The steering angle sensor would have come up due to flat battery and may correct itself with a quick drive, or you may need to follow the wiki guide to reset it. Leave the wheel over for 30 seconds on the lock to lock procedure as sometimes it doesn't take first time round if your too quick!
    54 8P2 A3 Sportback 2.0TDI BKD - Shark stage 1 - EGR delete - Dolphin Grey
    Tay
    May 2012
    Warrington
    366
    Yeah that's what I was thinking to be honest, was debating whether to get the breakdown people out to check if my battery is dodgy. May as well make one call out for the years membership!
    c_w
    1,061
    Yes the steering angle/warning light comes on with a flat/disconnected battery; it should clear after a short drive.
    As for the battery sounds like a big drain or a dud battery. Check the alternator too is putting out about 14.4v with the engine running at the battery.
    Tay
    May 2012
    Warrington
    366
    Quote Originally Posted by c_w View Post
    Thanks, well I've just gone and bought a battery after realising it has never been replaced so may have lost alll life now. Is this a specific channel in measuring blocks in VCDS so check alternator supply voltage?
    Oct 2012
    139
    Quote Originally Posted by Tay View Post
    Wouldn't bother. A battery place tested mine, claimed it was fine but my starting issues persisted. Replaced it anyway with Varta Silver bought online and all my problems vanished.
    As another poster said to me, these cars require a stable and high quality power source. So get the Varta Silver.
    Tay
    May 2012
    Warrington
    366
    All sorted now, Bosch Battery fitted the only one didn't seem to hold charge at all suddenly. Had to reset the basic setting for the steering angle sensor and then reset the calibration for steering limit stop aswell and power steering returned instantly
    Cheers for the advice people.
    Nov 2012
    16
    Boon
    having the same problem,what is wiki guide
    2,159
    Are you having problem with battery drain, or the steering angle sensor?
    Nov 2012
    16
    Hi bud,it's only started since my battery went flat,I fitted new Bosch battery tonight and still have power steering alarm.
    2,159
    Just seen your other post, when you took it out for a drive did you take a fair few corners left & right hand as it need them to get calibrated. Also if you have vcds then have a read of this wiki. VW Golf (1K) Steering Assist - Ross-Tech Wiki
    Nov 2012
    16
    Hi bud,yes took the car for a spin last night,and even went to work in it this morning,still the same.going to take it to this place in Warrington it's only round the corner.I have tried the above.
    Independent Audi, BMW Specialists Warrington - Mini Servicing
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    Sounds like you need someone with VCDS to reset the steering angle & limits, it doesn't seem to 'learn' them itself
    Simple job for someone who has a Ross-Tech lead & software
    Nov 2012
    16
    Can I buy one in the UK
    Nov 2012
    16
    Just got the car back so far so good,they reset the code and told me the starter motor was bad so fitted a new one,also fitted new earth cable.starts on a button now
    just hope the battery drain fault has gone.what sort of readings should I get AMPS when everthing is switched off
  1. Steering Angle sensor (G85) mechanical malfunction.
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2013, 10:27
  2. steering angle sensor
    By Techimike in forum General Technical / How To
    Last Post: 4th December 2008, 09:22
  3. Steer angle sensor,
    By MONKIEE in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2006, 22:22
  4. Vag-com, steer angle sensor, 2000 S3
    Last Post: 23rd May 2006, 20:01
  5. Steer Angle sensor, location
    Last Post: 14th May 2006, 18:06
