Friday,26,April,2013,13:54:22:30197
VCDS Version: Release 11.11.5 (x64)
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 77
VIN: WAUZZZ8P38A****** Mileage: 107040km/66511miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G4FNU04W
Coding: 01030003180F0060
Shop #: WSC 06314 000 00000
VCID: 377B6EE2463871A0D06
2 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 5
Mileage: 106615 km
Time Indication: 0
Date: 2013.04.19
Time: 20:09:38
Freeze Frame:
RPM: 836 /min
Load: 15.7 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 31.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.970 V
000406 - Engine Oil Temp. Sensor (G8)
P0196 - 004 - Implausible Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:36:44
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 13.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 10.287 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
VCID: 72ED9FF66DDAD488278
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AH HW: 8P0 820 043 AH
Component: KlimavollautomatH19 0420
Revision: 082921 Serial number: 8P0820043AH
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:35:41
Freeze Frame:
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007178923
Coding: 918E0F07A03210004F0000000000000000084E175A060202000000000000
Shop #: WSC 06314 000 08192
VCID: 4587142A0CD4133052A
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
2 Faults Found:
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 2
Fault Frequency: 4
Reset counter: 222
Mileage: 106994 km
Time Indication: 0
Date: 2013.04.22
Time: 20:30:00
Freeze Frame:
OFF
Voltage: 11.90 V
OFF
ON
OFF
OFF
OFF
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 00:00:00
Freeze Frame:
OFF
Voltage: 9.40 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 N HW: 8P0 959 655 N
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CR0G04L30
Coding: 0071612
VCID: 4D972C0AD4A4EB709AA
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78F9ADDE0BA6BED819C
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 981 L HW: 8P0 920 981 L
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2244G001000602
Coding: 0005428
Shop #: WSC 00383 210 83674
VCID: 418F003A18FC3F106E2
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0752386A7
Coding: E9831F060006020101
VCID: 306955FEA356A69891C
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 366563E6413288A8CB0
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G4FNU04W
Shop #: WSC 00481 210 88137
1 Fault Found:
01176 - Key
008 - Implausible Signal - Intermittent
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H02 0040
Coding: 0000560
VCID: 43830A3202E02D007CE
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.150 H08 1901
Shop #: WSC 02069 000 90108
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H10 0080
Coding: 18802020025849290505489AC637
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
00323 - Vehicle Inclination Sensor (G384)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000560
VCID: 4481092E07EE2A38454
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D777CCA64045BF00AA
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 195 G HW: 8P0 035 195 G
Component: R Symphony2+ H16 0280
Revision: 00H16000 Serial number: AUZ1Z4G9068609
Coding: 0410101
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005147587
Coding: 0000122
VCID: 3E757BC6690240E8130
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 22: DTCs cleared
Address 25: DTCs cleared
Address 42: DTCs cleared
Address 44: DTCs cleared
Address 46: DTCs cleared
Address 52: DTCs cleared
Address 55: DTCs cleared
Address 56: DTCs cleared
Address 77: DTCs cleared
Chassis Type: 1K0
25-Immobilizer -- Status: OK 0000
Readiness: 0110 0101
Revision: 00H13001
Coding: 0021128
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:35:41
Freeze Frame:
Coding: 00062736
Shop #: WSC 06314
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0000012
Coding: 0005428
Coding: 0000001
Coding: 0000560
1 Fault Found:
000 - -
Coding: 0000560
Coding: 0000012
Coding: 0410101
Coding: 0000122
Chassis Type: 1K0
08-Auto HVAC -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
1 Fault Found:
P0196 - 004 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:49:06
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 9.0°C
Temperature: 14.0°C
Voltage: 10.160 V
Revision: 00H13001
Coding: 0021128
Coding: 00062736
Shop #: WSC 06314
3 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:53:00
Freeze Frame:
OFF
Voltage: 8.35 V
OFF
ON
OFF
OFF
OFF
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:48:00
Freeze Frame:
ON
Voltage: 9.70 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0000012
Coding: 0005428
Coding: 0000001
Coding: 0000560
1 Fault Found:
000 - -
Coding: 0000560
Coding: 0000012
Coding: 0410101
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 7
Mileage: 107046 km
Time Indication: 0
Date: 2013.04.26
Time: 05:54:29
Coding: 0000122
