Monster MotorsportChris Nott
Results 1 to 14 of 14
    Apr 2013
    13
    HELP GETTING SLIGHT WOBBLE THROUGH STEERING AND FEELS LIKE THROUGHT THE FLOOR PAN..
    hi guys just joined this forum to see if i can find out what maybe the cause and fix to a ever so slight vehicle shake through the steering wheel and also feels like its going through the vehicle as you can feel it on the passenger side. under acceleration does get worse but after 40 mph it stops ???? have new tyres all round and balanced. can anybody advise...
    pluves1's Avatar
    Dec 2008
    346
    Quote Originally Posted by damenw View Post
    Do you have Quattro?
    Now
    MY10 BMW 335d Touring (Sapphire Black)
    MY10 S3 Sportback (Sprint Blue)
    Previously
    06 BMW 330d M Sport Touring Le Mans Blue with Black leather, Phone Prep
    Apr 2013
    13
    no its an Sline a3 1.9 tdi DSG
    Mar 2012
    46
    It maybe that a newly fitted weight has fell off the wheel, being a nearside wheel its subject to manhole covers and potholes more. Id check that first, hopefully its something as simple as that.
    Apr 2013
    13
    maybe could be issue. not checked weights. there should be 2 sets on the wheels top and bottom opposite to each other . is that correct. if its not this what other reason could cause this problem...
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    2 of the same thread?
    Anyway, it's not a case of "should have 2 here and 2 here", each wheel needs to be balanced individually. Only way to check the right weights are on is to get them rebalanced.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Apr 2013
    13
    okay thanks will look into the balancing see if that solves the problem
    RPB
    Aug 2011
    Notts.
    318
    I'd still be thinking wheel balancing too. To be honest there are some really good tyre fitters out there now and with the new equipment I have not had a case of this for a lot of years.
    2011 61 plate S3 SB BE DSG - Shark Stage 1 + DSG
    blackshuck's Avatar
    Aug 2012
    Taunton, Somerset
    443
    It's most likely the balancing as others have said! However if you have front spacers fitted and there not hub centric this will also cause similar issues,
    Ad-Man
    2002 S3 more mods to come.
    Double J's Avatar
    Jun 2012
    London
    49
    Quote Originally Posted by pluves1 View Post
    I get this with Quattro...what's the difference?
    blackshuck's Avatar
    Aug 2012
    Taunton, Somerset
    443
    I don't get any wheel wobble with Quattro
    Ad-Man
    Double J's Avatar
    Jun 2012
    London
    49
    No I mean why specifically mention Quattro, is there a common fault?
    Mine was fine until I horribly bottomed out one time...
    TDI140's Avatar
    May 2011
    1,350
    Could be wheel balancing, tracking, or i had this with budget tyres as they came on the wheels when i got them but i switched a week later and the vibrating had gone
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Could also be buckled wheels.
    8P2 S3
  1. Odd vibration sensation through steering and floor
    By A4CAB in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th March 2010, 22:04
  2. I feel like throwing the towel in - More Than insurance
    By Miss Audi Cab in forum Insurance - Sponsored by Sky Insurance
    Last Post: 12th March 2010, 21:09
  3. serious vibrating through steering wheel and pedals?
    By jarvis**turbo** in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2008, 22:02
  4. Heavy Steering and Battary warning light on ___ Help
    By rockfanatic in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 1st July 2007, 18:32
  5. Pulsing through steering - Can anyone help??
    By simon_golf_tt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2005, 18:18
