Volks AutosAH Fabrications
Results 1 to 9 of 9
    Apr 2013
    2004 3.2 A3 Quattro, 3 Beeps when Starting
    Hi everyone, this is my first post on here, hopefully you can help me out. After not having a car for a few years due to saving for my own place, i've picked up an 04 A3 3.2 Quattro, 8P. Had several VW Mk2 GTI's in the past, but decided to go for something a bit more refined this time round. Still getting a feel for it, but very pleased with the car so far. However, I have a slight "niggle" with it. When starting sometimes - usually from cold, I get 3 beeps from the dash area. At first I thought this was when the temp was low and it showed the frost symbol, but I've noticed it has been doing it when the temperature is higher too. I get no flashing symbols or lights on the display that I can see. I've been reading that other models sometimes have this issue when the alarm batteries are low? Anyone experienced a similar problem? Thanks!
    Apr 2013
    Aberdeenshire
    593
    Think it's your alarm battery back up warning you failing/flat get a scan carried out with vcds for fault codes I have vcds but am in Aberdeen perhaps someone local can assist for beer tokens.
    Apr 2013
    Thanks chillout, from reading online, that's pretty much what I thought myself. What exactly is VCDS? I'm actually in Aberdeen at the moment myself! Any idea how easy/hard it is to replace?
    Apr 2013
    Aberdeenshire
    593
    Quote Originally Posted by paulclaude View Post
    vcds is a diagnostics cable and program for vag cars it costs around £280 how long are you in Aberdeen for or do you live near I have googled it and the battery can be replaced if you are handy with a soldering iron you can get battery's from places like rs or maplins I think it is located under the left hand panel in the boot but don't start ripping your car to pieces yet not a 100% sure on location.
    Apr 2013
    I see, found out via a quick Google, looks a handy tool to have indeed. I should be here all weekend, but on standby for going offshore at the moment. Found a guide for the Mk1 S3 that indeed says it is in the boot. Soldering wouldn't be an issue. Would be nice to confirm it's that though like you say, before ripping things apart! Has anyone else with an 8P had this problem, and located the battery unit?
    Apr 2013
    Aberdeenshire
    593
    I could try and scan it but this weekend is a bit busy
    Apr 2013
    Thanks Chillout. I may be here after the weekend so if you are available it would be great if you could scan it for a pack of beer or something?
    Apr 2013
    Aberdeenshire
    593
    I will be around Dyce on Monday or Tuesday morning so if you pm me your mobile no I will give you a shout if not i am in Dyce so for work a lot so meet you on your return to dry land or something ?
    Apr 2013
    Well thanks, that is good of you. I'll get my mobile number sent. Not sure I could manage through the day mon/tues as I have to report to the office, but may be able to arrange something.
  1. HELP! - 2004 Audi A4 1.8t Quattro (B6) wont start!!!
    By skyline-sl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th June 2009, 00:50
  2. 4 beeps when starting S3
    By S3MHT in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2007, 13:07
  3. noise when starting
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2004, 08:02
  4. S3 Beeping on start up
    By ben in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2003, 12:22
