JMB RetrofitsVolks Autos
Results 1 to 14 of 14
    Sep 2012
    Milton Keynes, United Kingdom
    47
    Lowered car on JOM Coilovers what drop links would be suitable ?
    I have got 2006 Audi 8P and I bought JOM coilies had those fitted, very comfortable although didn't come with drop links, any suggestions it's seems like quite a far distance from coilies to the drop link bar (which ATM bangs on wishbones).
    JPK
    May 2012
    278
    FK tuning does adjustable end links and so does whiteline. I have whiteline on my car and they seem to work well.
    2005 A3 2.0T DSG Oettinger Body Styling, 19" RS5 Reps, APR Stage 1, Forge Twintake, Remus catback, BSH PCV Fix, 034 Motorsport Mounts, WALK, Whiteline bushings (F&R), Whiteline RSB, Whiteline BSK, Whiteline adjustable end links, H&R Sport Cup Kit, Stoptech Drilled Rotors, Hawk Pads, Tyrolsport stainless lines, Tyrolsport Calliper bushings, Tyrolsport DeadSet Subframe kit.
    Sep 2012
    47
    Thanks bud, where did you purchase yours ?
    JPK
    May 2012
    278
    In NZ. ECS tuning has them or just find a whiteline dealer locally.
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Quote Originally Posted by Black View Post
    Hmm. My joms were wound right down and never hit anything! I actually had miles of clearance. Standard drop links too. Strange.
    Oct 2012
    Warrington, North West
    986
    What's ride comfort like on these compared to standard setup?
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    Quote Originally Posted by TimG View Post
    do JOMs have helper springs? You may have left yours in and the OP may have removed his.
    JPK
    May 2012
    278
    In relation to clearance, i never had a problem with this. I'm not a suspension expert, but I upgraded mine so I could reduce preload on the front sway bar and back within spec after lowering.
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Quote Originally Posted by chris.vincent3 View Post
    Good theory but no helpers on joms. Actually i know have fks, with the helpers removed, and im evn lower than i was on joms by a good 30mm and still nothing hits!
    Sep 2012
    47
    I will probably fit my original drop links back on, it's catching on wheel arches it seems like I need some stretched tyres. 8,5 J should i go for 205/40/18r? Link to my build thread to see how low it is atm --->
    Build Thread: Patrick's A3 8P in Black
    TimG's Avatar
    Feb 2004
    South Coast
    932
    What et?
    Sep 2012
    47
    What et?
    Ummm, I think it is 35 sits flush with the front arch
    TimG's Avatar
    Feb 2004
    South Coast
    932
    If its 35 youll defo need a 205, although my guess would be your wheels are 45 in which case a 215 will suffice to obtain clearance needed.
    Sep 2012
    47
    thanks bud, your help is much appreciated honestly. I do have picture, but I can't tell if it's 35 or 45, I will need to take them off tomorrow and have a look.
  1. JOM coilovers and shortened drop links
    By antdsg in forum DPM Performance
    Last Post: 12th August 2012, 11:31
  2. Coilovers and drop links
    By BuuBBa in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2012, 09:34
  3. will i need shorter drop links after lowering my car?
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th December 2011, 01:25
  4. Car on coilovers is it worth shortening the drop links?
    By s3dave in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th December 2010, 17:29
  5. What are arb and drop links?
    By zeeeebo in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2009, 14:01
