Sky InsuranceAH Fabrications
Results 1 to 12 of 12
    Mar 2013
    56
    '55 2.0 tdi DSG 75k PRNDS Flashing. Tempremental won't start
    Hi gents
    I have had my A3 for a couple months now and done about 3000 miles on it.
    The other day I went to drive it (having had it running fine that morning) and it wouldnt start. PRNDS was flashing on the dash and it would simply turn over but not start.
    I have taken it to an Audi specialist in my area and they ran diagnostics and a few checks and can't figure out what is wrong with it as of yet. It sometimes starts instantly and runs fine and other times it just wont.
    Anyone got any ideas. It is FSH, 75k on clock and was running perfectly up until now.
    Apr 2013
    Aberdeenshire
    592
    Think the best thing you could do is get your car scanned for faults with vcds or similar also meantime you could check your fuses As that at least eliminates that i also think a dsg reset can be done with vcds .
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Transmission control module failing?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Poor battery connection and/or alternator.
    Mar 2013
    56
    Well it's been in the garage for a week and even they dont know what is wrong with it. One minute it starts and runs perfectly, the next minute you turn the key and get all the PRNDS flashing on the dash and it will turn over but not start.
    As I said when started, (approx 50% of the time) it runs normally. But the other 50% it will turn over but wont start.
    Might have a bit of an electrical gremlin/ poor connection in there somewhere? It was running perfect one minute and then all of a sudden this problem occurred.... we're scratching our heads. Any input appreciated
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by llekra View Post
    Could a bad earth be the cause as some are in vulnerable places behind the left headlight are earth post one under the headlight (hard to see) and one further back visible just thought its worth a try
    Mar 2013
    56
    When the problem first happened last friday, on the dash it came up with a headlight warning message at the same time as the flashing PRNDS. It hasnt mentioned it since though. Might that be connected at all?
    Mar 2013
    56
    When I turn the key and have the issue it comes up with the error message 'headlight range control defective'.
    On the occassion I turn the key and PRNDS isnt flashing and the car starts fine, I dont get this error message.
    Thoughts?!
    Mar 2013
    56
    A video paints a thousand words!
    Audi A3 DSG PRNDS flashing - YouTube
    Apr 2013
    Aberdeenshire
    592
    Could it be your brake switch I have manual so have only driven a dsg for 5 minutes
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,207
    Wasn't this related to the mechatronics unit?
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Mar 2013
    56
    Well after lots of scanning, head scratching, checking of electrical connections earths etc etc we have decided to replace the Gearbox ECU / Mechatronics Control Unit.
    From Audi these are silly money so am going to try a reconditioned one and will report back in a few days as to how we've got on.
  1. 99 2.5 TDI - engine cut out and now won't start - timing issue? fuel pump?
    By mattupnorth in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th August 2012, 10:43
  2. 2004 Audi a3 tdi - DSG - P R N D S flashing???
    By danrowe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th April 2012, 23:46
  3. Questions to upgrade a new A3 2.0 TDI DSG
    By imported_ilclifford in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2004, 12:53
  4. INFO REQUEST FOR 2.0 TDI DSG S-LINE
    By imported_BAVO in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th August 2004, 09:26
  5. A3 2.0 TDI DSG S-LINE
    By imported_BAVO in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th August 2004, 00:12
