Sky InsuranceVolks Autos
Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Chillout
Thread: A3 esp and steering lights on after smash
    Apr 2013
    mansfield
    87
    hi to all new to this forum and hope someone can help.i purchased an a3 with front end damaged bent chassis legs had it all straightened on car-o-liner jig back to within 1mm.when I got the car both esp and dynamic steering lights on.now the car is straight how can I get these off or will they go off on their own thanks.location notts/derby
    Apr 2013
    Aberdeenshire
    592
    Have you driven the car as that lights will come up when the battery is disconnected and will clear once driven failing that you will need to have the car scanned.
    leeds2592's Avatar
    When I grow up, I want a 964!
    Apr 2012
    Leeds
    1,180
    Visit leeds2592's Instagram Channel
    Welcome mate.
    You can get these fault codes cleared by using VCDS which will result in the lights going off the dashboard. Although, they may just come back on when the car is driven if there is an under lying problem.
    Black 2007 2.0 FSI Sport
    2011 Glossy Black RNS-E |AP Coilovers | 18" 7 Spoke OEM BE Alloy Wheels | H&R Trak+ Spacers 8mm (Front) 12mm (Rear) | MY11 Rear Lights | S Line Spoiler | Retrofitted MFSW | Retrofitted Cruise Control | Interior LED Light Pack | OEM LED Numberplate Bulbs
    Apr 2013
    mansfield
    87
    haven't driven the car yet battery was dead when I got the car so new one fitted.will the lights go off when driven?
    Apr 2013
    mansfield
    87
    seen I kit on amazon for £37 is it worth buying or shall I go to garage?
    Apr 2013
    Aberdeenshire
    592
    Drive it and they will reset after hundred yards or so if not you have an issue
    Apr 2013
    mansfield
    87
    will try it and post back.
    leeds2592's Avatar
    Apr 2012
    Leeds
    1,180
    Yeh, if the battery's been dead, give it a drive first to see if the lights go. If they don't, best thing is to scan it to clear codes and see what fault codes are coming up.
    I wouldn't recommend the cheapo cables you can get off Amazon and eBay, but some garages that use proper VCDS can charge a lot for a 'diagnostics scan' which literally takes 5 mins. Stick a thread up on here and I'm sure somebody local, with VCDS, will help you out for a few beer tokens.
    Apr 2013
    mansfield
    87
    will give it a go
    Apr 2013
    mansfield
    87
    how far do I have to drive as no mot and it wont pass mot with lights on will it?
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by dallo View Post
    Not far 30 meters or so
    amit87 likes this.
    Aug 2012
    Milton Keynes
    86
    not very far, about 100yards as someone mentioned, I disconnected my battery and took off steering wheel etc etc and lights wer eon, drove literally 10m and they turned off.
    Apr 2013
    mansfield
    87
    your a star it worked only drove down my drive and they disappeared thought it was going to be more expense thanks.
    Apr 2013
    Aberdeenshire
    592
    I was like o f#$k when I disconnected my battery and the lights came up too
    Apr 2013
    mansfield
    87
    thanks
  1. ESP and ABS light on
    By jimmp in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2011, 10:21
  2. Help! Esp and brake lights on after DIS and cruise fit
    By rob irl tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2010, 15:59
  3. ESP and EPC Light Staying On And Engine Revs Up & Down??
    By pazaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 20:34
  4. Bit info on esp and battery light and radio
    By 02audis3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th October 2009, 18:07
  5. 1.8T ESP and EPC lights have come on
    By M4KTT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd December 2008, 01:39
