Volks AutosEM Tuning
Like Tree1Likes
  • 1 Post By Chillout
Thread: Battery is completly flat!! HELP
    Jan 2013
    40
    My battery is completely flat on my a3 3.2 v6 so flat that i cant use the remote central locking to open the boot to get to the battery! Anyone got any other ways of opening the boot? Can you open it from the inside??? Also i heard its not a standard battery,
    What battery do these take? Its an 04 plate? Cheers
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by dalejones View Post
    Jump it from under the bonnet on the battery posts
    amit87 likes this.
    PaulRS3's Avatar
    UK
    1,006
    The issue is opening the boot! As the battery is IN the boot.
    A 12v supply on cigarette lighter would get you going.
    I can highly recommend Ctek mxs5.0 intelligent battery charger. Best £50 I've spent, multiple accessories, and if your cig lighter is a permanent non switched feed, you can charge from there.
    Can you fold the seats down from inside and get at it that way?
    Audi RS3
    Apr 2013
    Aberdeenshire
    592
    If you connect the jump points to a 12 volt source central locking can be operated car started etc unless the drivers door is delocked it should not be a problem and then the cause can be investigated ( battery or charging issue or a drain)
    The Thread is flat battery help so flat I can't get in the boot. for easy jump starting connection points are under the bonnet this does away with the need to access the battery LOL
    Jan 2012
    SW London
    794
    Alternatively, u cud go into ur boot from inside the car and use the manual release hidden under the tab in the centre of the boot
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Apr 2013
    Aberdeenshire
    592
    Too much hassle for me personally 8-10 bolts to remove the battery cover or a bonnet catch I would go bonnet catch every time I also would look for current drains such as radiator fans or maybe it's human error that caused the discharge lights left on etc
  1. Audi A6 4f battery going flat help needed.
    By Agriv8 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 7th October 2012, 17:35
  2. Batterys flat, help please
    By vince, A3 turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2012, 22:09
  3. Really need an s3 plastic battery cover can anybody help? thanks
    By bowers210479 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2009, 19:00
  4. complete refit help!
    By nasher1001 in forum In-Car Entertainment
    Last Post: 13th February 2008, 08:49
  5. Flat battery and electrical drain....HELP!
    By CJA318T in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 09:08
