AH FabricationsSky Insurance
Results 1 to 15 of 15
Like Tree4Likes
  • 1 Post By bo
  • 1 Post By JRock247
  • 1 Post By chilly
  • 1 Post By andyherd
Thread: Stupid question time
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    Hi folks,
    After cleaning my motor the other day I noticed the fuel filler neck area was horribly dirty so I blasted it clean with the pressure washer. However the water was not draining away in the filler neck through the drain point (small white insert).
    I reckoned its blocked and tried to clear it by pushing the shank of a small drill bit down it but it was solid. I can't get on vagcat at the moment to see the arrangement of the filler neck but was hoping for some useful advice.
    Jan 2012
    51
    Try a wire coat hanger mate
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Try a can of compressed air with a small nozzle, wedge it in there and blast the crap out.
    bo
    bo's Avatar
    May 2010
    48
    Poke it
    Darylaas likes this.
    JRock247's Avatar
    Jul 2012
    Hampshire
    315
    Quote Originally Posted by bo View Post
    Poke it
    Very helpful
    Aug 2011
    277
    I assume it's not some sort of blanking plug. The other end of what is likely to be a rubber tube with the outlet under the car somewhere is not the place to poke from as there might be an integral one-way flap fitted. If you can clear the initial crud try some flexible curtian wire and solid wire might damage or puncture the tube walls
    TDI140's Avatar
    May 2011
    1,293
    Shoot it with a shot gun but make sure you miss the tank because there will be an explosion !
    But seriously just get wire hanger it will clean it out same thing happened with mine
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Sep 2012
    37
    Amazing answer!!! like it ......... thats almost topgear thinking!
    TDI140 likes this.
    Past Motors
    Golf Tdi
    Fiesta Zetec S
    350z
    Current Rides
    S3
    A3 TDI Quattro
    Flat Out
    Apr 2007
    Essex
    144
    Had the same with mine, cleared it with a piece of semi ridgid wire. Overflow comes out the rear wheel arch.
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    Thanks chaps, will be trying the wire option this weekend. But I've got the shotgun on backup
    TDI140 likes this.
    Apr 2013
    Aberdeenshire
    585
    Blow it out with carb cleaner or similar with a tube attached
    TDI140's Avatar
    May 2011
    1,293
    Make sure the shotgun is sawn off as a normal pump action wont cover the whole area lol
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    Just a quick update to let anyone with the same problem know the solution. I had a roll of solder wire about 1-2mm thick which I carefully pushed down the drain, I felt a bit resistance at a couple of points so worked it back and forth to clear out the dirt. The water drains out just behind the wheel arch.
    Next stupid question whilst I'm here: whilst swapping my front and rear wheels to even out the tyre tread wear I noticed the front hub nuts did not have a cover whereas the rears did, am I missing a couple of front covers?
    Front
    Rear
    Apr 2013
    Aberdeenshire
    585
    Your fronts are your driven wheels so they are un capped.
    andyherd's Avatar
    Oct 2010
    Dumbarton, Scotland
    70
    Quote Originally Posted by Chillout View Post
    Thought that was the case but I recalled a mk2 Golf that had covers which made me wonder. Thanks
  1. two stupid questions??
    By benjy in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2006, 18:12
  2. Stupid Question
    By jdp1962 in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th October 2004, 19:51
  3. Stupid question!
    By imported_RastaS4 in forum The Welcome Section
    Last Post: 6th September 2004, 11:27
  4. maybe a stupid question
    By dummi in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th March 2004, 18:27
  5. Stupid question...
    By V1RDE in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2003, 18:18
