EM TuningJMB Retrofits
Results 1 to 8 of 8
    May 2012
    13
    Strange Idle/Rough - Intermittent
    Hi,
    help and advice please folks??
    I have an Audi a3 3.2 v6.
    Following various vagcom scans, I replaced the MAF for a genuine Bosch air flow meter after some intermittent running problems.
    Now, when I'm driving it usually only when it's warm, I come to a stop and the revs take a couple of seconds to drop down to its idle point, making pulling away uncomfortable/difficult.
    I had an episode last week where I would start it up and it would die immediately unless it had revs!!
    This problem stopped, I am sure it is related.
    Car is still drive able, but not enjoyable.
    What does this sound like???
    Ta
    May 2012
    13
    Anyone?????
    Apr 2011
    Essex
    30
    Try a throttle body reset with vagcom
    2004 Avus Silver 3.2 S Line DSG
    Spec - RNS-E - PhatNoise Media Player - Bose - Bluetooth - SDS - MFSW - Cruise - Reverse Camera - Reverse Sensors - Interior Light Pack - Black Headlining - Custom Code Stage One
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    601
    is it possible to adjust idle on these engines?
    Apr 2013
    Aberdeenshire
    592
    Think you can adjust the idle don't know how mine idles at around 640rpm I had a rough idle before I had the audi software update however I still don't think my car idles perfect I take it no codes were logged and the basics are ok like fuel and air filters throttle body alignment is probably not a bad first point of action though along with a clean in case it's sticky
    May 2012
    13
    Throttle body being cleaned out tomorrow morning.
    Presumably the garage will reset the TB using vagcom after??
    Apr 2013
    Aberdeenshire
    592
    [QUOTE=3.2Sline;1854776]Throttle body being cleaned out tomorrow morning.
    its easy to do it you self I think if you disconnect the battery for a while then reconnect it and turn your ignition on the car will align its self only take a minute you will hear the high pitch noise
    Apr 2012
    UK, Portsmouth
    601
    Don't always presume the garage will do that.
    And to adjust idle on my TDI is as follows..
    Ignition on - engine off
    Select Engine controller 01
    Select Measuring blocks 08
    Select 'Go' in Group 1
    Start Engine ( you may be able to start engine earlier but I don't )
    Hit 'Turbo' button at top of page
    Select 'Done'
    Select Adaptation - 10
    Change channel to 06 and hit 'Read'
    However maybe slightly different for you.
    Also, what fuel are you using? This has been a known problem for cheap fuel.
  1. Strange idle issue
    By Dubstep in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2011, 22:47
  2. HELP PLEASE !!! - idling rough
    By AudiJohn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th January 2011, 09:37
  3. Strange idle
    By quattro rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2010, 15:41
  4. Strange idle video evidence normal sound?
    By basscrazy in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th April 2009, 15:15
  5. Strange idle problem
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd March 2009, 09:58
