Can anyone tell me the name of the part in the picture. Its located at the top of the engine and was making a whistling noise from the rubber gasket,seal underneath. The german based on a google translation warns about it being spring loaded.
Could it be the cause of the Engine management light coming long during a recent trip and a noticeable drop in power (like extra weight was added to the back all of a sudden) until the engine is switched off and restarted after which the power returns and the light is gone, the vagcom reports an "000665 Boost Pressure Regulation p0299 - 000 - Control Range not reached mil on" error
Is this part connected to that error message and would replacing the part in the picture solve my problem?
Finally is it an easy part to source and actually replace if it is the likely cause?
Complete VagCom Error
000665 - Boost Pressure Regulation
P0299 - 000 - Control Range Not Reached - MIL ON
Freeze Frame:
Fault Status: 11110000
Fault Priority: 1
Fault Frequency: 2
Mileage: 157732 km
Time Indication: 0
Date: 2013.04.22
Time: 17:20:37
Freeze Frame:
RPM: 2037 /min
Speed: 113.0 km/h
Load: 58.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
Absolute Pres.: 1836.0 mbar
Absolute Pres.: 1377.0 mbar
Readiness: 0 0 0 0 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Mileage: 157732 km
Time Indication: 0
Date: 2013.04.22
Time: 17:20:37
Freeze Frame:
RPM: 2037 /min
Speed: 113.0 km/h
Load: 58.0 %
Voltage: 14.36 V
Bin. Bits: 00000000
