JMB RetrofitsBadger5
Results 1 to 15 of 15
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    276
    Issues since cambelt change
    I had my cambelt & waterpump changed last week (not at Audi) and since then there has been a rocking motion coming from underneath the car, you can feel it when sat in the car stationary with the engine running on idle, to the point where the whole car is juddering.There's also much more movement from the engine itself when you lift up the bonnet than what there was before. Obviously my initial instinct was that the timing was off, but the tech has shown me the markers are lined up so he reckons that's not it.The car's already booked in at Ipswich Audi this weekend to have recall injectors fitted...tech says that might be the issue but it's too much of a coincidence that these problems only occured after he'd worked on it don't you think?Anyone know what it might be?
    Oct 2012
    73
    Could any of your engine mounts have been loosened when cambelt was done to get better access maybe and then not tightened up correctly??
    Apr 2013
    Aberdeenshire
    592
    I would check your lower rear engine mount especially it might be a good idea to do this before your appointment as you don't want your engine to land on the Tarmac !
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Could the timing be out?
    VCDS USER
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    I'm guessing its a TDI?
    If so they done your cambelt with the standard locking tools which still allows movement on the cam & haven't set your KW/Crank angle/Torsion Value... Mainly because they know sweet FA about it!
    Do a search for someone local on the forum with VCDS to measure your settings. Then adjust as required, 3 bolts on the front cam, 3 on the rear. Search the forum for a how to as its quite a common issue & been covered extensively.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    max69vk's Avatar
    Apr 2012
    745
    RE: engine movement - It's worth checking the O/S engine mount as it has to be removed to do the cambelt.
    Oct 2012
    119
    Did you fix this?
    I've just spoke to two different VAG garages about this and they're both pointing me to injectors.
    As this has been happening since November (when I got the cambelt changed) I'm either living on borrowed time or it is the timing!
    How much is it to get the timing checked and adjusted?
    Lewis583's Avatar
    Mar 2010
    870
    On the 2.0tdi engines when changing the timing belts there are locking pins which should be used to lock the cams.
    With the cams locked you then slacken off the cam pulleys and tension the new belt. This is to ensure that there is even tension on the belt all the way round and that any minor differences in length of the new belt don't affect the timing.
    Pretty much exactly what a fella a couple posts above said. You need to check the timing values with VCDS.
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
    Oct 2012
    119
    I had a look for an how to before on this.
    I have VCDS - can you point me in any right directions?
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    276
    Quote Originally Posted by granty578 View Post
    Did you fix this?
    Well, it went in to Audi and had the injectors changed and yes when it came back out, the problem was sorted. However I can't say for sure if it was the injectors which made the difference for all I know they tightened something up like engine mounts while it was in and could have been that...
    2006 A3 2.0TDI 170 S Line Mauritius Blue
    Bluetooth | RNSE | MFSW | BOSE | DRL | Xenon Plus | Half Leather | Heated Seats | Parking Sensors
    Oct 2012
    119
    Quote Originally Posted by immo View Post
    How much did that cost? Eeep...
    immo's Avatar
    Stop me
    Mar 2013
    Suffolk
    276
    It was a recall part so didn't cost me anything.
    Oct 2012
    119
    Ah yours is the 170....
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Mounting bolts should not be re-used. Perhaps Audi tech torqued to right setting without knowing if bolts were changed.
    Imteyaz's Avatar
    Oct 2008
    Warwickshire
    526
    Have a read of my post that I have just put up: Broken engine mount bolts.....
    Seems like Audi have no idea what a torque wrench is these days.....
    Imteyaz.
  1. Rough idle after cambelt change
    By in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2005, 18:19
  2. 2.0 TDI Cambelt change & warranty situation
    By funkycat in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2005, 14:40
  3. Cambelt change 2.8Q 30v
    By imported_christhick in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd February 2005, 16:46
  4. 2001 210BHP S3 cambelt change
    By Mehdi20v in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2004, 09:20
  5. Cambelt Change?
    By imported_stuartkern in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2004, 14:56
