Sky InsuranceChris Nott
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Question Brake Bias settings
    After replacing some rather shockingly worn brake pads on the motor at the weekend I've noticed that the brake bias seems to have shifted more towards the rear of the car. I've checked the fitting & cycled the ABS & its made no difference, after doing a bit of online searching it appears that the braking bias is meant to be set more toward the rear for safety i.e to keep the car more level under braking?
    I cant say that I'm 100% that this is correct as I used to get a fair bit of nose dive under heavy braking before the new pads were changed fitted (though this could be down to the knackered pads. The car stops fine enough although it does feel a bit strange as if being dragged to a stop rather than the previous nose-diving, dont get me wrong I've tried some heavy braking and the front brakes & ABS do kick in + a couple of hundred motorway miles & the brakes were working very well at slowing from high speed. Its just the balance feels a bit 'weird'.
    Does anyone else have any further knowledge on this?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    crunchie's Avatar
    Oct 2009
    Inverness
    865
    My S3 shows a lot more brake dust on the rear wheels compared to the fronts.
    Stripped them down a couple of times and stroked full length on the pistons and they are free as a bird.
    Don't remember them being quite as bad 2 years ago when I bought it with 12k on the clock, its now showing 26k.
    I wasn't sure if there was a load compensator as such on them?
    Now:
    TTS, Leon Cupra R, MK2 Golf GTi 16v BB 3dr & MK4 Golf "GTi" 2.0 8v
    Past:
    S3 8P3
    A3 2.0T
    S3 8L REVO
    306 Rallye
    Impreza STi8
    Leon Cupra R REVO
    S3 8L REVO
    Impreza T2000
    306 Rallye
    MK3 Golf GTi 8v
    & more in between
    Jan 2012
    477
    Quote Originally Posted by crunchie View Post
    Really? My fronts are always caked and the rear ones are virtually clean!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,863
    im the same, id say it was time for a caliper refurb for the op
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    max69vk's Avatar
    Apr 2012
    745
    I think there's a possibility the front pads are just taking a little longer to bed in than the rears, although at lower speeds the rear brakes appear to be biting reasonably equally with the fronts which gives a much more 'level' stop i.e. no nose dip/dive. At higher speeds or emergency braking the front is definitely working harder & there is the expected dip/dive & ABS kicking in under very heavy pedal use.
  1. Any way to adjust the front/rear brake bias?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th September 2012, 08:49
  2. how much are these worth: AUDI S3 FULL BRAKE SET UP.
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th September 2010, 18:12
  3. Best way to post a set of brakes?
    By jojo in forum General Chat
    Last Post: 29th August 2010, 15:22
  4. What brake set up do people have ??
    By S3 Paul in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2009, 16:36
  5. S4 (B5) brake discs/pads torque settings
    By SlipMat in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2008, 16:39
