AH FabricationsVolks Autos
Results 1 to 10 of 10
    Oct 2012
    Grove Park, S London
    24
    Fault Code Reader
    Hi Guys,
    Bit of a newbie here to the Audi - I have a 2006 2.0TDI A3 and when buying it from my mate the engine management light has been on for quite a while. He said he got it checked and its the MAF sensor and describe it as a butterfly valve which needs changing. I was thinking in investing in a fault code reader off ebay for cheap and checking myself:
    Audi A2 A3 A4 A6 A8 Fault Code Reader Scanner diagnostic scan tool | eBay
    That seems a bit too cheap to be any good - has anyone got one? Does it work ok?
    Also if it is the MAF sensor I have had a look and it seems quite easy to change as its just located at the top of the engine with the air box? She described it being expensive due to labour costs as it is hard to get to - maybe she was thinking of something else? Currently the car drives fine but the engine does vibrate a bit more than expected during idle.
    Any ideas or advice would be much appreciated.
    cheers
    seenan
    Apr 2013
    Aberdeenshire
    580
    Quote Originally Posted by salam0506 View Post
    Hi Guys,
    cheers
    seenan
    The maf sensor is between your air box and engine it measures air entering the engine so the cars computer can calculate injection the preferred diagnostic tool is vcds/vag.com watch out for fakes though it covers audi,skoda,vw and seat and costs around £280 it is very usefull it's the next best thing to a dealer tool however you could just ask a local forum member to do a full scan of your car
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    MAF is very easy to replace. Costs around £80 from eurocarparts or audi.
    VCDS USER
    Oct 2012
    24
    Thanks guys, so do you think the £10 fault code reader from ebay is deff not worth getting? Do you think I should just put a message up in the general group asking if anyone nearby could do a fault code check on my a3?
    If it is the MAF sensor that needs replacing - will that improve performance at all? or is it more so fuel economy?
    Jan 2012
    367
    I bought one of these - only reads the engine ECU and even then not all the modules. Also I've never seen a failed MAF show up with a specific fault code. Try cleaning your MAF sensor using Isopropyl Alcohol (from Maplins) first.
    HTH
    Oct 2012
    24
    so the engine management light on the dash board is most likely not the MAF sensor?
    Oct 2012
    Warrington, North West
    956
    Where abouts are you located?
    Oct 2012
    24
    I'm in tunbridge wells, kent but obviously willing to travel within reason
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    683
    Sounds more like the EGR rather than the MAF.
    The MAF is 2 clips to remove, has no butterfly flap and is located on pipe work at the top of the engine. Also with a dodgy MAF you get no power above a certain point, it also won't flash a light on the dash.
    The EGR & shut down valve have a butterfly flap & are bolted to the EGR feed pipe, turbo pipe & intake manifold at the front of the car. This can be a pig to remove (often easier to remove the whole manifold) & work on. If this is faulty it will flash a light on the dash.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Oct 2012
    24
    Have any of you guys had much experience with the "eliminate EGR" kits? Do they improve performance but sacrifice fuel economy? Will it make a difference to emmisions values for MOT? Hard to install?
    Also anyone of you guys near tunbridge wells or in kent at all?
  1. Fault code reader ecu question?
    By jay1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2012, 16:59
  2. Fault code reader - which type ?
    By AudiJohn in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th January 2011, 17:46
  3. Fault code reader/scanner
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th January 2009, 17:15
  4. Fault Code
    By gman in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2004, 16:44
  5. fault code
    By tp7n in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th December 2003, 14:05
