Badger5Chris Nott
    Aug 2012
    75
    Manual transmission won't go into any gear
    As the title say's i can't it get into any gear. I can only get to any gears if the engine is shut off. My car will move if i shift into first gear, then press the clutch pedal and start the engine but as soon as the engine have started i can't get into second gear up to 5th gear. The clutch pedal can still be depressed and upon release it will return into original position. Help!!
    This all happened yesterday while driving. When I shifted from 3rd to 4th... when I tried getting into 4th nothing happened..... it just got stuck. I got the car towed with audi roadside but have to wait until tomorrow to see what the dealer says.... my car only has 10k miles on it. What do you guys think it can be? A lot of my friends in the scene are saying it might be slave cylinder/hydraulic problem or my TCM (transmission control module).... do you guys think that could be replaced under warranty or am I screwed and have to dish out $$$$ ?? If i have to dish out $$$ that would ruin my AirRide plans before sowo
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,370
    May be the selector fork which is apparently a known weakness in this gearbox.
  1. Audi A4 1.8T manual Transmission Fist gear noise
    By nemohawk in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th December 2012, 11:04
  2. Won't go into gear with engine on - fine once moving
    By Squirrelofdoom in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd November 2012, 11:05
  3. DIY-Clutch Renewal-Manual transmission
    By Gordon in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd February 2006, 23:01
  4. Crunch going into third gear?
    By S3K in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2005, 17:36
  5. remote start on manual transmission s4
    By indica in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2003, 20:56
