Chris NottAH Fabrications
Results 1 to 9 of 9
    Apr 2010
    10
    S3 odd power loss
    I've got an '09 S3 with MTM remap and turbo-back exhaust. The mod's were done years ago and have given no issues. However, I just noticed an odd loss of power around 3500 rpm. If I floor it, the engine accelerates up to around that point, then hesitates like I took my foot off (can actually see the rev counter drop briefly back), it then recovers and accelerates ok past that point. This is most noticeable in high gears where the revs build more slowly. I can't imagine that I wouldn't have noticed this before. No recent changes to the car, although just filled up with new flavour Shell VPower. Suspecting some engine or management system issue. Any ideas?
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by SaintToad View Post
    This is very funny, this is the second report of this new shell fuel causing trouble.
    I'd use most of the fuel you've put in and put some BP or the like in instead, let it adapt..
    Then report back...
    Failing that, spark plugs, coils...
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Ben S3 8P3's Avatar
    Jul 2012
    Bury//Manchester//Leeds
    313
    ESP/ASR problem? Coil pack/spark plugs?
    Ice Silver Audi S3 (8P3) https://www.facebook.com/benjamin.n.long
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by Ben S3 8P3 View Post
    Clutch?
    revs would continue to rise with no extra forward motion, not hesitate.
    Ben S3 8P3's Avatar
    Jul 2012
    313
    Quote Originally Posted by mjr901 View Post
    Yep sorry I edited it when I re-read the revs didnt climb
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,786
    Sounds to me like this fuel is upsetting ignition timing, running a touch rich perhaps.
    I'd get it scanned to check for mis-fires etc
    Apr 2010
    10
    Thanks all. Will try the simple thing with the fuel first and take it from there. Usually run on VPower with good performance, so would be wierd, not to say irritating, if Shell's change to the formula has upset it. Will let you know how I get on...
    Nov 2004
    Tonbridge, Kent
    912
    The fuel thing is probably coincidental as they are just really rebranding.
    It's best to get it scanned and see what faults arise. Mine played up a bit with the intake manifold flap.
    Where abouts are you based as it may help people with vcds who could scan it for you?
    Hope you get it sorted.
    Apr 2010
    10
    Demo'ed the problem to one of the local Audi tech's today: clutch! Recommendation was to fit an uprated one to cope with the engine mods rather than replace with OEM. Now talking to Autohaus Edinburgh about fitting an APR Stage II Daily one, or possibly Sachs.
  1. Intermittient Power Loss
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:30
  2. Power Loss / Turbo Problems??
    By pafitoui in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 11:38
  3. S3 Power Loss
    By gbhdavies in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2004, 12:41
  4. Power loss @ wheels massive on Quattro!
    By dans3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th July 2003, 17:32
  5. Power Loss On S3
    Last Post: 9th May 2003, 15:06
