Chris NottBadger5
    Raincheck's Avatar
    Sucking diesel..!
    Mar 2013
    Dublin
    97
    Exclamation How to remove sub woofer panel
    Hi forum,
    I would like to replace the sub woofer enclosure but need to remove the panel first.
    Found one screw (see photo) but no clue how to proceed. (2011 A3 Sportsback 1.6 TDi 5 doors)
    Help is more then welcome.
    Rain.
    _G_
    _G_'s Avatar
    Jul 2011
    869
    IIRC the seats need to come out to access this panel.
    1. Start by using a flat head screw driver to remove the black retaining clip between the seats in the boot (you can see it in your photo)
    2. Loosen the screw and keep it safe
    3. Remove the seats... might be easier to remove the rear bench first
    When you have removed the seats access will be much easier...
    Have a look at this... this is what I have:
    dizzythedog.com
    This system cannot be touched! The amp is mounted in the rear quarter panel on the passenger side.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    if its similar to a 2006 sportback, then take out parcel shelf and everything out of boot. take off the trim bit where the warning triangle is. then just a few screws and it will come off !
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
  1. how to remove lower dash panels in 2009 A3 ?
    By RST in forum In-Car Entertainment
    Last Post: 28th January 2012, 14:00
  2. How to remove climate control panel..
    By Loneranger in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th September 2009, 21:05
  3. Sub Woofer removal
    By Von Maximo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2007, 15:55
  4. How to remove trim panel under steering wheel?
    By Lovegroover in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th October 2006, 10:35
  5. How to gain access to the SUB-Woofer
    By FSI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2005, 16:24
