JMB RetrofitsSky Insurance
    Feb 2012
    Blackburn/Reading
    44
    Clutch noise/ brake pad warning light
    had my 57 plate 1.9tdi now just over a year in the past 6 months or so iv heard a vibrating/knocking noise coming from the cluth when its in nutral but once your put the clutvh down it would go. my dad thinks its the clutch bearing but it had no affect on the car driving it was just annoying really when idle. recently its started getting louder and it happens when the clutch is in nutral and when its pushed down. you can play about with the clutch pedel and it will go but soon enough the noise is back. want to know what my options are really at dealing with this problem
    also the brake pad light came on a few weeks ago had a look at the pads and the back ones were low so go them replaced thinking that was the problem but i noticed the rear didnt have a senor on to tell the car they where low so i pressume it must be the front with a faulty sensor because the fronts are like new. anyone else had this problem with a faulty sensor?
    any help would be much appreciated
    Oct 2012
    Warrington, North West
    986
    I'd say your rattle sounds like a possible DMF. Or indeed possibly a clutch release bearing. I have no idea regarding your brakes tho as I haven't got round to mine yet
    Edit: does the noise go when AC is on/off?
    Apr 2013
    Aberdeenshire
    592
    I agree it sounds like your flywheel or clutch release as for your pad warning light you should have continuity through the sensor if not and the pads have more than 25% thickness left you could probably just crimp the wires together on the sensor side that's if it's a 2 wire sensor.
    Feb 2012
    Blackburn/Reading
    44
    So what options have I got on fixing the clutch problem then?
    Apr 2013
    Aberdeenshire
    592
    Quote Originally Posted by cammy104 View Post
    By the time you get the gearbox out to do the clutch bearing it is probably worth just doing the flywheel and clutch if your are going to spend that sort of cash that is if you plan to keep the car .
    Apr 2013
    yorkshire
    11
    options vary depending on history of when things were last changed .I just had the clutch,bearing, dual mass flywheel and slave cylinder changed for nearly £700 inc labour (AUDI DEALERS CHARGE ABOUT£1400 FOR THE SAME)
  1. Brake Pad Warning Light?
    By K-Dash in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2011, 22:23
  2. Brake pad warning light wont go off!?
    By mrpies in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd April 2009, 21:47
  3. brake pad warning light
    By avanted in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th October 2008, 00:59
  4. brake pad warning light
    By jays3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2008, 10:22
  5. Brake pad warning light reset???????
    By 46TheDoctor in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2007, 08:27
