Badger5Monster Motorsport
Results 1 to 9 of 9
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    It's back again. Grrrr
    About 6 months ago I had a problem where my car would put out a cloud of light grey/blue smoke every time I pulled away from idling.
    At the time I cleaned the egr, all the intercooler pipes, checked the turbo and took out some oil as Audi had filled it to just over the max mark.
    About a week after doing all this it just stopped by itself and has been fine since then.
    Then, about a month ago I was getting a cloud of grey diesel smoke on cold start up and it was a little lumpy for about 2 seconds, but I put this down to the very cold weather. Just to be sure, I put a double dose of Millers Diesel treatment in with a full tank of Shell V-power. Shortly after this the weather changed and my start-up smoke totally vanished, only to be replaced with my old problem of smoking when I pull away.
    I'm lost now. It can't be anything like turbo, valve stem seals or tandem pump otherwise it wouldn't have sorted itself out last time and been perfect for 6 months.
    I've ran a VCDS scan and found no faults. I then checked the injector readings with VCDS and got the results below, which I believe are acceptable:
    Inj 1 - 0.00
    Inj 2 - 0.35
    Inj 3 - 0.30
    Inj 4 - 0.00
    Has anyone got any ideas why the smoking has returned? At the service when they overfilled the oil I'd also had a new sump fitted, so I'm wondering if something is wrong and the dipstick might be reading wrong. I'd just topped up the oil before the smoke started again, but only 2/3 of the way between min and max because I'm nervous of overfilling it.
    It doesn't seem to be using oil any more than normal and the coolant level never moves.
    Help me please!
    I want to sell the car and get an A3 black edition, but nobody will buy it with it smoking like this.
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    After a lot of searching and thinking, I've seen mentioned about changing the temperature sensor.
    Does anyone know what sensor they mean and where it's mounted?
    The temperature gauge reads normal, but is there another sensor that would have an effect on fuelling or something?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Is the car remapped or standard?
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by max69vk View Post
    It's just bog standard.
    TDI140's Avatar
    May 2011
    1,350
    Overfilling oil will damaged your cat causing oil to sit in the exhaust and cat so your car will smoke until the exhaust is clear and sorry to say your cat could be knackered now if its got oil in it and smoke will be normal
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by TDI140 View Post
    It was only about 3mm above max when Audi gave it back to me and I removed most of it quite quickly. Surely if my cat was full of oil and knackered then I would've thought it'd smoke all the time, rather than stop for 6 months and then come back again. Wouldn't it smoke all the time or would it just happen when I pull away from idling?
    TDI140's Avatar
    May 2011
    1,350
    Yes it would smoke all the time if oil was sitting in the cat
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Well at least I can rule that out. Being smoke free for 6 months and then only getting it after idling for a while doesn't sound like the cat's oily.
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Just been thinking, the smoke started about 75 miles after filling up with Shell V-Power and a double dose of Millers Diesel Power Ecomax (to try to get rid of the start-up smoke, which it did).
    The Millers stuff says use within 12 months of opening. I can't remember when I bought this bottle, but if it was out of date then would this cause smoke?
    I've emailed Millers, but not had a reply yet.
    I'm trying to use up the rest of the tank of fuel so I can fill it up with a fresh tank from BP, but for once this tank seems to be lasting forever!
    I can't for the life of me remember if I'd used this stuff last time I had the smoke problem.
  1. Back Again !
    By stoakseya4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2008, 14:59
  2. Back again
    By huskydcts3 in forum The Welcome Section
    Last Post: 16th December 2007, 20:40
  3. Back again!
    By Zoom Zoom in forum The Welcome Section
    Last Post: 2nd March 2007, 15:03
  4. This old chestnut back again
    By Rev-head in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th September 2006, 09:14
  5. Intermittant blower 8D2 820 021 back again
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2004, 12:00
