AH FabricationsVolks Autos
Thread: part numbers
    harvz's Avatar
    Dec 2011
    60
    part numbers
    hi i was going to buy a wiper stalk to control the trip computer as my car does not have one yet.
    My car is pre facelift (2004-2008) 2008 8pa a3 1.9tdie. I spoke to audi they said the part number is
    8P0953519E. However this is for 2008+ models post facelift?
    I found the part number for 2007 to 2008 models is
    8P0953519A. I asked audi if it will fit my car and they go its the same but different software?? Im sure 100% wiperstalks dont have software in them only hardware.
    Was wondering if an expert here could let me know if i install the
    8P0953519A on my car will it be ok? as its the only part i can get hold of.
    I have also bought a cruise control module from an 2005 model here:
    http://www.ebay.co.uk/itm/261191988813?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2648
    Fossie
    Rhubarb Triangle
    3,969
    Don't know what you're trying to do but the part you have bought is not the cruise control module !
    That is the CC stalk but you need the correct steering control module for it to work. The firmware is in the steering module.
    It is not possible to say if it will work without knowing what your steering module is. You need to get the car scanned with VCDS to check steering module version.
    If your car is not fitted with trip computer then you will need a new cluster as well.
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
  1. Oil used in servicing part number
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2003, 15:39
  2. TT linkage for A3 part number
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 16:58
  3. TT pedal set part numbers
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 9th April 2003, 20:20
  4. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
  5. ECU part number
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 12:49
