Sky InsuranceChris Nott
Results 1 to 17 of 17
    Apr 2013
    yorkshire
    11
    loud bang and no power
    recently had clutch fly wheel slave cylinder and cambelt changed.
    Today there was a loud bang and lots of smoke from exhaust as i changed from 1st to 2nd gear now it sounds like a tank and has no power.
    any suggestions
    Apr 2013
    yorkshire
    11
    its a 2006 1.9 tdi 105 bhp version
    Apr 2013
    Any ideas on what colour the smoke was?
    Apr 2013
    yorkshire
    11
    black smoke
    Jan 2012
    SW London
    757
    Sounds like the turbos gone, could be wrong. Although the fact u had ur cambelt changed could suggest that it may have been done wrong, full throttle from first to second with dodgy timing may have caused something to go wrong in a big way.
    The "tank" sound is how the car sounds with no boost pressure, i've experienced this plenty of times when my car had EGR probs, it had minimal power, enough to drive it somewhere but couldn't do no more than about 40-50.
    Plooms of white smoke from the exhaust is normally what u'll find when the turbo finally gives in.
    Apr 2013
    Its best to get it checked out, My turbo just blew and i have an automatic so could not stall the car. Its scary!! Mine put out a literally cloud of grey/white smoke for miles high until engine finally turned off.
    Apr 2013
    yorkshire
    11
    black smoke not white
    sunday driving style not giving it any beans
    Jan 2013
    Wiltshrie
    85
    Check your boost pipes as one could of been taken off when work was carried out and not clip together properly
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    Id say your boost pipes have blown off.
    Happened to me, had new pipes and the turbo reconditioned to fix it.
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Dec 2012
    Hordnean, Hampshire
    154
    If it's not a boost pipe then it may be the turbo. I'm less familiar with these but in an old car I had I got a loud bang with similar results - turbo housing had cracked between the exducer and wastegate port.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,607
    +1 on the boost pipe!
    happened to me!
    luckily the large one just needed a new jubilee clip
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    688
    Boost pipe = black smoke
    Turbo = white/blue smoke
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Apr 2013
    ah yes, deffo boost pipe popped off.
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    518
    I agree with Max above normally black smoke is over fuelling caused by the ecu and other components recognising there is too much air so its starts chucking fuel in to compensate it over boosting,turbo light grey white smoke and depending on how the turbo has gone but a good symptom is it chucking out the light coloured smoke on tick over and it clearing when you rev it until revs drop down to tick over again.
    Check the boost hoses properly all of them give them a tug both ends to make sure they are not pulling out of what they are housed in,as sometimes the metal clips break but not fully so underload the pipes are pulling apart
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Apr 2013
    yorkshire
    11
    all sorted now
    thanks for the reply`s
    i took the guard off underneath the engine to find a bit of oil on the front nearside of the guard the pipe above had come out of it`s mounting i think the circlip wasnt fitted correctly
    thanks
    Mick
    Dec 2012
    Hordnean, Hampshire
    154
    Sweet
    May 2012
    West Country
    172
    Quote Originally Posted by A3Craig View Post
    My moneys on this as well. I was into the tuned
    tdi scene before coming here. Uprated clips are sometimes the answer.
    Full Stainless Mikalor Supra W4 (Pro) Hose Clamps
    No power as you are probably going into limp mode.
    2009 S3 3 door. Phantom Black metallic.
    RNS-E, Tints, Piano Black inlays, Auto Lights and Wipers, Bluetooth, MFBSW,
    White Alcantara, LED numberplate lights, Black Optic Grille, Yellow Foglamps,
    K&N panelfilter, Colourmatched mirrors, S3 footplate,
    More to come....
  1. ESP, ABS and now Power steering warning
    By r10jdl in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th August 2011, 17:20
  2. Solution for loud banging from rear suspension!!
    By jbkudos in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2009, 20:48
  3. A3 2.0 TDI 170HP Quattro - 230km'h and strange power loss issue
    By ronald_adi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2009, 13:17
  4. for those with DSG and Tdi power
    By marriedblonde in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2005, 08:26
  5. CD Changer Cable, and boot power
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th February 2005, 07:38
