Volks AutosSky Insurance
    Apr 2013
    100
    Are these readings right??
    2003 a3 2.0tdi
    i have been fine tuning the cams to cure a vibration and bad idle! The car seems to be runnin okay now at 800 rpm!
    I have set the front cam (closest to radiator) to 0.0 kw (torsion value) the rear cam i adjustet untill the car idles smooth! Now i read somewere the consumption should be around 0.6 l/h and the engine torque no lower than 28nm! Now my readings are: 0.6l/h-0.4l/h
    and stays at 0.4 l/h when fully warm! And my engine torque moves around from 28-32nm does this sound okay? Also my torque request (driver) is -2.0nm! Are all these readings okay and normal or is there something wrong?
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    682
    The lower the l/h reading the leaner the mix at idle, nothing wrong with that. I wouldn't worry about the other readings, as long as the car is running ok don't worry
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted!
    Bits for sale...
    Genuine S-line 18" alloys, A3 Sportback rear lights. A3 5dr window switches & mirror switch. , Brand new PD170 engine cover. PM for details.
    Apr 2013
    100
    Thats good then! When i started it yesterday after being left all night it started okay but then had a wobley for 5-10 seconds! Something would squeke now and then and when it did it would miss! But then was okay all day! Still yet to try it thismorning!
    max69vk's Avatar
    Apr 2012
    682
    When one thing goes wrong on a car it can be easy to over analyse everything else that you hear/feel etc, chances are these things were there already but you hadn't noticed to the other issues.
    Your best bet is to run the car for a good few hundred miles so it can 'settle' with its new adjustments & chances are 90% will rectify themselves
    Bits for sale...
  1. Are these the right keys for my head unit?
    By Harribo66 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th April 2012, 14:09
  2. Are these the right bits?
    By niallh in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd December 2011, 16:48
  3. Are these the right Saab reds?
    By B5QUAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th September 2011, 09:47
  4. What RIMS are these ?? (pic inside)
    By TurboNut in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2004, 00:24
