JMB RetrofitsEM Tuning
    Nov 2010
    25
    what grade oil for a A3 tsfi 1.8t petrol 59 plate
    As above really
    also do these cars use a lot of oil
    shady-ninja's Avatar
    857
    5W 30 grade. yes it drinks quite a bit or a lot.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    8P2 S3
    Nov 2010
    25
    cheers shady
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Mine uses about 1/2 litre per 3k miles.
    But every engine is different with consumption as much as 1 litre / 500 miles!!!
    Sump will require 4.5 litrs of oil if filter changed at same time.
  1. Thicker grade oil for multitronic??
    By AudiiduA in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2010, 15:24
  2. Just a quickie! S3 what grade oil???
    By S3 Eddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 17:27
  3. What transmission oil for S3
    By Triple_A in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2005, 13:08
  4. What is the best oil for a A6 2.8 quattro/98
    By imported_MADEIRA in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd March 2005, 20:50
  5. What Oil for T Reg A3 1.6, How much required?
    By mspah in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th June 2004, 07:58
