Volks AutosChris Nott
Results 1 to 22 of 22
Like Tree2Likes
  • 2 Post By mike foster
Thread: Whats the normal idle rpm a3 2.0tdi??
    Apr 2013
    100
    I have set it to 800rpm and the vibration seems to have gone but i want to know what the standard idle rpm is so i can check if it vibrates now on that!
    May 2012
    York
    241
    IIRC mine idles abit higher than that, nearer 900-950
    Fossie
    Rhubarb Triangle
    3,969
    840 is about standard but I have set mine at 800. Seems fine at that but wasn't too bad at 840 !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Mar 2011
    Cleveland
    979
    Mine's just over 800 and you don't know it's running!
    tdi-man's Avatar
    Jul 2009
    1,611
    just to run mine at 860 but just altered to 800 running fine
    Full Leather / heated Seats / 18" Speedlines / AP coilover kit / R32 Rear 310mm Brakes / window Tints / Auto lights / Xenons / Cruise control / R32 Front 345mm Brakes / Full milltek system / Led side lights / Bose / brushed aluminium inlays / panal filter / Full Egr delete / custom map with hot start fix / Hybrid Turbo / Sachs Racing clutch / 10mm Rear spacers / 10mm Front spacers / A5 LED number plate bulbs /
    233 bhp - 309 ft lb - 419 nm (NEEDS A NEW MAP)
    Oct 2012
    Warrington, North West
    986
    Where do you access this in vcds? Wouldn't mind having a whirl with this
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by Mikemc View Post
    Check out this but ignore the comment about 'version 908'. Still works with version 11.11.5
    how to turn tick over up
    martinivw and chris.vincent3 like this.
    max69vk's Avatar
    Apr 2012
    Kingston upon Thames
    745
    Running mine anywhere between 740-780 depending on what done to the car at that point. Anything above 810rpm seems to make things a bit 'lumpy'.
    TDI PD170 S-Line Sportback... 191.2bhp & 290lb/ft torque @ standard with an iffy turbo! No idea with the new one or Shark Stage 1 remap installed, DPF off Stage 1 ready to go, Suspension & wheels to be fitted... Still....
    Nov 2005
    Tyne & Wear UK
    62
    Wots the benefit in having lower tick over?
    Fossie
    Rhubarb Triangle
    3,969
    Quote Originally Posted by cmgreen View Post
    Quieter, smoother and cheaper ??
    max69vk's Avatar
    Apr 2012
    745
    Definitely quieter & smoother, although go too low & it has the opposite effect.
    Aug 2010
    160
    777 worked for me came from audi set at 840 but its become rough at that idle and injection quatity is very up and down so not sure if changing the idle down can mask injectors on the way out maybe
    TDI140's Avatar
    May 2011
    1,349
    I noticed mine was juddering and rev needle was shifting at 800-840 ish due to egr boost hose not being fitted by mechanic properly but now idles at about 875 or very close to that
    A3 2.0TDI FWD sportback with GT1756 250.3bhp 336ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch BBS CH
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Put mine down to 800 for AGES and it ran great, but just had to INCREASE to 925rpm (can't seem to get it higher than that) as judder at idle returned ,
    Probably due to cambelt stretching a bit, I will need new cambelt done before summer
    I'm sure I heard timing should get checked 1/2 way through cambelt life cycle
    TDI140's Avatar
    May 2011
    1,349
    Cambelt stretched ? How come has it been replaced before or would this be the first cambelt change?
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,207
    mines just around 780, although when its cold its as high as 900!
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    Quote Originally Posted by TDI140 View Post
    They just stretch over time, my car will be going for 2nd cambelt before summer mileage is now at 121,600miles
    will get done at 125000 ish miles
    TDI140's Avatar
    May 2011
    1,349
    Oh right yh that sounds about right mate cambelt every 60K miles, are you running high power through the engine ?
    sliced's Avatar
    Jun 2012
    1,207
    thought it was every 75? :$ If not i'm well overdue
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    I was sure my mkIV GOLF tdi was @ 50000 and when we bought the A3 a m8 of mine said timing belts should be 75000 or 5years, so I done it at 60000,
    power figs were unknown as I used a powergate unit to change map and car drove great for 40000ish miles on std turbo, but after a problem with my hybrid turbo,map was switched back to standard so I can go down custom map route
    TDI140's Avatar
    May 2011
    1,349
    So your running hybrid turbo ? What company did you use as ive ordered one from turbo dynamics stage 2, also what turbo have you got on thecar now ?, and the cambelt change is recommended every 75K but i changed mine at 60k aswel just after 5 years old
    martinivw's Avatar
    Jul 2008
    TheShire
    381
    car has crturbos stg 2 hybrid on it since oct last year
    before then it was std turbo
  1. whats the best hybrid turbo for my a3 2.0tdi 140 ?
    By olliea3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd March 2012, 10:59
  2. what is ur idle rpm
    By teo420 in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th July 2011, 22:47
  3. Whats the best 'range' you've got too?
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2003, 15:38
  4. What the hells a RUF ???
    By ooooaudi in forum Other Brands & Models
    Last Post: 8th April 2003, 06:47
  5. Whats the most bizzare object you have ever hit?
    By gtdog in forum General Chat
    Last Post: 2nd February 2003, 17:44
