Results 1 to 14 of 14
    Apr 2013
    14
    Rear washer fault
    I have a a3 1.8tfsi and my rear windscreen washer isn't working any ideas what the problem is??
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    403
    Hi Suzy,
    Can you hear the pump running when you try and use it? - If so flip up the little black tab on the wiper and you should see 2nozzles, make sure that they are not blocked - If they are not blocked i would remove the boot liner and make sure that there isnt any leaks, as leaking washer can lead to damaging the boot actuator,
    Jonny
    Black Audi A3 8P 2.0TDi
    V-Maxx Coil overs | S3 Rear Spoiler | De Wiperd | TTRS Alloys | S3 Rear Bumper | S3 Side Skirts | Votex Front Spoiler | LED Ring in Fogs | LED Interior Lights | LED Number plate lights | Custom Foot well lights | DPF Removed | Green Cotton P/F | JBS Phase 2 | Pressed Plates | LED Side lights | Custom Rear Light tint | Complete Matt Black Plasti Dip | Honey Comb Front Grill | Silvertec Indicators | BOSE | Sunroof | Forge Short Shift
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    they have a tendancy to get clogged if you get something thin enough to cleanem out it usually works, best to look for any of the fluid sitting in the tailgate as this is also common too
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    Apr 2013
    14
    Ah ok thanks the pump is running and when I purchased the car it's was damp in boot and a lot of condensation so I will check for blockages.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Suzy84 View Post
    Take it back because you will need a new wiper motor !
    2006 2.0L BKD 140 Sportback RHD ( manual, with extra bits incl. mfsw ) Gone
    2012 2.0L TDI Q3 S Line Quattro
    Apr 2013
    14
    Well the motor is fine it's working and it ain't blocked so its leaking somewhere.....
    Oct 2012
    Lincoln
    148
    The motor might be working at present, but if there is water inside it, then over time it will rust the inside of the motor and then cause it to cease up.
    Apr 2013
    14
    Ok thanks for that advise much appreciate
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    685
    When u checked to see if they were blocked did u pull the washer off and try operating it? Just a thought as I tried a needle down mine and it didn't work then I pulled the nozzle off and operated it to see if water came out.I then soaked it in warm water for 5 mins and blew through it.
    Audi A3 2010 2.0 TDI 140 Black Edition
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by davesimmo View Post
    Exactly !
    Suzy, you don't say what year the car is but if it's '04 -'07 then it's a very common problem. It can also cause the alarm to falsely trigger because the leaking gets into the boot lock and and corrodes the microswitch.
    The only fix is to get the motor replaced with the latest version and think yourself lucky the washer pipe has not split elsewhere as it can in freezing weather with insufficient anti-freeze. I had a leak where the pipe is jointed inside the offside boot panel right over the comfort control module !
    Believe me that is not funny !
    It all happened to me 3 years ago and the only cure is a new motor !
    Apr 2013
    14
    My car is a early 2008 model s line
    Fossie
    Rhubarb Triangle
    3,961
    Ok for '04 - '07 read '04 - '08/09 !
    Suzy, believe me, your rear wiper will eventually have a mind of its own and start working without warning. If you have washer fluid/water in the spare wheel well then a new motor is required.
    Please take it back to the dealer and ask for a fix. If it is not under warranty then a VAG specialist will do it for you cheaper than Audi.
    Apr 2013
    14
    Ok will get quotes and get someone to fix it and get new motor then hopefully it will solve my problem thanks guys.
    dj_woodster's Avatar
    Mar 2013
    Midlands
    26
    Had this on mine £80 from Audi Lincoln on Ebay for a complete rear motor, just had a friend at the garage swap it for a few pints.
  1. Avant rear washer water gone...
    By chazzy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th January 2006, 20:55
  2. Rear washer pipe split in engine bay
    By koonl in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th April 2004, 20:25
  3. Rear Washer
    By bkmullin in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th March 2004, 14:41
  4. Rear Washer Problem 2
    By Woodster in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th March 2004, 20:06
  5. S3 rear washer jet problem
    By Mike.M in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2004, 15:34
