Sky InsuranceAH Fabrications
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By jb0o
Thread: RNSE 2010 reverse camera help please
    rikbbb's Avatar
    Sep 2011
    Cambridge
    17
    Hi,
    I have a 2010 RNSE (glossy screen surround, media button and chrome knobs) and I'm looking to fit a reversing camera. The problem I have is enabling the auto switch function when you put the car into reverse gear. I've done hours of hunting on forums but can only find info on the mk1 RNSE. Any one managed to get this working? Any help would be appreciated.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,571
    I've got it on mine and it works, but its not great. The CANBUS auto switch will flick to the camera when reverse is selected and will stay for a second then will momentarily flick to the previous screen, then back to the camera. Very annoying.
    Relatively easy to wire in. I ran a wire from the Reverse Feed in the Central Electrics board to the RFSL of the RNS-E and connected my interface reverse +12 feed to this wire.
    To sum it up, it is possible, but the auto-switch has a glitch which annoys the life out of me.
    Audi A3 2.0TFSI S Line SE DSG
    JMB Retrofits - North East Retrofit Company
    Oct 2012
    Australia
    10
    Hey what is the model number of the RNS-E? Also are you using the kufatec IMA?
    I have been trying to figure out a way to get this working on a 193G versrion RNS-E but no luck yet...
    rikbbb's Avatar
    Sep 2011
    Cambridge
    17
    Really want this to work flawlessly if I'm gonna invest the time and money in it. It's a G version RNSE. Was looking at a multimedia adaptor on eBay to send the camera signal in on the TV channel.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    My method works on all MK2 193 RNS-E's.
    i've taken a video of mine to show the flicker. I'll upload once Im back from Uni.
    My interface is an AV adapter that runs through the TV channel like you said.
    Oct 2012
    Australia
    10
    Oh that is awesome news that you guys got it working at least. Do you have a link to the adapter you are talking about? rikbbb, what adapter are you using at the moment? everything works fine except auto switching in reverse?
    rikbbb's Avatar
    Sep 2011
    Cambridge
    17
    Quote Originally Posted by jb0o View Post
    How did you wire the reverse signal into the RNSE and what coding did you use?
    rikbbb's Avatar
    Sep 2011
    Cambridge
    17
    Quote Originally Posted by David A3T View Post
    I haven't bought an adaptor yet as I want to make sure it's going to work first. The adaptor I'm looking at;
    NEW! Plug&Play AV multimedia interface - RNS-E TV DVD - AUDI A3 A4 A6 | eBay
    Just plug the camera into this interface and then plug into the back of the RNSE. Should work fine by selecting the TV on the RNSE but I want to have it so the RNSE automatically switches to the camera when put into reverse.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Quote Originally Posted by rikbbb View Post
    I mentioned above about the wiring mate:
    Off the top of my head (did this retrofit last year) the coding was only to code the RNS-E for the TV and code in the adaptation channels that it has a Rear View Camera and thats it.
    Uploading video to YouTube now so you can see the screen flicker. I assume that the only way this would be fixed would be if a software patch was released, which won't happen any time soon.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Here's the video of the flickering:
    Ignore my commentary :D
    Also, I'm still yet to determine whether the distortion at the top of the screen is due to the camera or the interface. Could be the interface with it being a cheap one, so be aware of this.
    rikbbb's Avatar
    Sep 2011
    Cambridge
    17
    I've read somewhere that if the picture signal is lost to the RNSE that it will automatically switch off from the TV input. Could be that as your camera and interface start up that they temporarily lose signal? You usually get this at home as you turn your TV on to HDMI or something and the picture flickers for a couple of seconds. Maybe worth trying wiring the camera and interface into an ignition feed instead so they are already powered up ready to go when the RNSE switches over to the TV input. You could run a cable straight off the battery as a test whilst it sits on your drive before running all the wiring.
    Just a thought. May not change anything, but worth a try?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Yeah, that would be worth a shot actually.
    The reverse feed (which sends +12v down the line when reverse is selected) is connected to the RFSL on the back of the RNS-E and I've connected the camera +12v to this too, so by changing the camera +12v to a seperate ignition feed, this may solve the issue.
    I was always under the impression that the flickering was due to the canbus checking system. ie, the rns-e picks up that it's in reverse then stays a couple of seconds, flicks back, but then releases reverse is still selected and goes back over.
    I'll keep you updated.
    Oct 2012
    Australia
    10
    Any update on this?
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,571
    Sorry mate, haven't had a chance to change the wiring yet! Got an assignment in on Monday so I'll be sure to sort it on Tuesday
    David A3T likes this.
    Oct 2013
    Las Vegas
    Any update on this yet?
    Oct 2013
    Las Vegas
    Ok, i just installed a 8J0-035-193D in my '03 Allroad and I have gone through the VAG coding, and since I had a first gen RNS-E already the wiring and Kufatec were already there.
    Could somebody please clue me in as to how to get the reverse camera to come up on the new RNS-E?? I'll deal with the VIM later..
    P
    Oct 2013
    Las Vegas
    Ok found it (adaptation channel)..Now I need to find out why the map/gps is'nt updating the position??
    P
    Rick_RS4's Avatar
    Dec 2010
    25
    i have the same problem, i can get the cam to show up when it is in tv mode, but nthing comes up when you put it in reverse, tried lambo mode and everything, i have connected a wire to the rfsl too but still nothing
    really annoying m now
    msullx's Avatar
    Apr 2006
    Portugal
    7
    Hello to all,
    I have a similar problem with my RNS-E Led 193B HW:02 SW:220. Also I checked RNS-E label and I can see pin RFSL in C2.
    My RNS-E Led is coded with 0215756.
    With my old rns-e (192A) my RVC was working just fine with Kufatec IMA and I got camera and auto switch every time I enter in reverse gear.
    Yesterday I installed my new RNS-E Led, just plug&play, code it whit VAG and in channel 004 I enter 1.
    As soon I entered 1, my rns-e screen goes blank, but unit keep it running, because I can listen radio, and I got rear camera with auto switch, but nothing more on screen.
    If I entered 3, my unit has normal screen but I don't get auto switch for rear camera. With code 3, I must press MEDIA button to have camera.
    With vag I can see an error in Navigation 37:
    1 Fault Found:
    03157 - Functionality limited due to Communications Disruption
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 57
    Mileage: 105534 km
    Time Indication: 0
    Date: 2013.12.14
    Time: 14:16:06
    Freeze Frame:
    Bin. Bits: 00001000 00000000
    Bin. Bits: 00000000 00000000
    Anyone knows a solution for this issue?
    Thanks in advance.
    Audi A3 8P (MY2006) 2.0 TDi, Sport
    EU RNS-E 8P0 035 193 B - (HW02, SW220, Coded: 0215756) with SDS
    BT 8P0 862 335 N - Coded: 11402 & Lumia 925 - MFSW Coded: 0004012
    IMA Plus, Rear View Camera (Rear camera not auto switch)
  1. Reverse Camera With & Ami Installed - PLEASE HELP!!!
    By Chris Coates in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2013, 16:21
  2. Has anybody retrofitted the 2010 reversing camera kit to an earlier A3
    By nevergivup99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2012, 07:37
  3. Aftermarket Audi Reverse parking sensors stopped working, help please?
    By Bailey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th August 2012, 20:28
  4. HELP ANYONE FITTED A REVERSE CAMERA?
    By mattyboyc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th June 2011, 19:19
  5. RNSE Coding - Help Please
    By geraint.davies in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th March 2010, 07:44
Tags for this Thread
