AH FabricationsEM Tuning
Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By chunk090883
Thread: rear arch gap help?
    Jan 2012
    surrey
    19
    rear arch gap help?
    1st of im new to the site so a quick hello, I have got an audi 2.0tdi sport, nothing special just 18s and twin back box at mo, have just ordered some eibach sportline springs, and trying to decide what alloys to get but the problem i have got is my car seems to be really high at the rear, the front seems to look fine, any ideas on why this is, guessing its not normal
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Eibachs should sort it. Can only be the springs!
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    I think a3s always sit high at the back IMO. Yours being a sport has the highest suspension set up too. Sline and s3 are lower so doesn't look as big.
    Your new springs will sort your Arch gap out you will probably sit with around 15mm gap
    monopole's Avatar
    Oct 2012
    240
    That gap looks tatally wrong compared to the front
    +incoming (64) S3 (300) Sportback S-Tronic Quattro Phantom Black
    -outgoing (63) A5 2.0TDI (177) Black Edition S-Tronic Coupe Quattro
    Phantom Black
    VCDS Location: NI (East Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    Aug 2012
    Essex
    67
    Quote Originally Posted by Jack_tdi View Post
    I've got a sport but I thought that the SE sits higher than the sport?
    Ads
    Ads's Avatar
    License to drive
    Jul 2009
    London
    8,146
    That arch gap at the back is definitely more than the usual arch gap on a Sport.
    What size wheels are they?
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    933
    Maybe it's a SE version not the sport?
    VCDS USER
    Feb 2004
    Borders, Scotland
    371
    I think what happens is people replace broken springs with non-Audi ones and when you do this they usually come in standard ride height, ie not Sport, not S-Line. Does anyone know how much lowered Sport and S-Line should be as I have a non standard srping on the back of mine making it sit a bit higher than it should?
    Jan 2012
    surrey
    19
    its a sport, i have got it booked in tomorrow to be checked, 1 garage said the springs at rear look quite new so maybe the previous owner has put the wrong ones, should hopefully get the new springs put on next week and start looking for new wheels
    Dec 2012
    Hordnean, Hampshire
    154
    Probably springs off a Q7
    As said, a set of Eibachs should sort it nicely
    Apr 2013
    Guernsey, C.I.
    31
    Beat me to it! I was going to post a thread about this as my sport sits exactly the same, I was getting worried mine was the only one. Was hoping that it was just something to do with the springs etc and not that the car had been rear ended or something like that in a previous life without being documented so it's good to know. As everybody else has said, the Eibachs will sort it out. I'm personally going for coilovers when I get some new wheels.
    Jack_tdi's Avatar
    Mar 2012
    Cumbria, England
    281
    rear arch gap help?
    Quote Originally Posted by MadA3 View Post
    I'm not 100% sure tbh
    But if the springs are from audi you can identify they by the colour markings I have some s3 springs they are marked as below. Maybe check someone else's with each model
    Front
    Rear
    TimG's Avatar
    Feb 2004
    South Coast
    932
    I have seen this loads before, including an A3 in my road that one day appeared just like yours, really high at the rear. I can only assume the wrong springs were fitted when the old ones broke etc.
    TDI140's Avatar
    May 2011
    1,293
    I had this to fix it i got 3 friends to sid in the car so thats 4 including me and then i drove it down a38 for 3 miles turned around and came back home problem solved the spring just stiffens usually because you have jacked the car up from the rear and springs havnt compressed to normal ride height
    A3 2.0TDI FWD sportback with GT1756 225bhp 351ft lb, forge boost hoses red, milltek decat system, BMC panel filter, golf gti edition 30 full front brakes brembo pads, black honeycomb grill, full oem s line kit + cupra r lip, LED side lights, OEM xenons, LED interior lighting, LED A8 number plate lights, boost gauge, alloy catch can with red hoses, FBSW, windows tinted, de-badged, now on air ride with chassis notch
    Jan 2012
    surrey
    19
    it was the wrong springs on the back, fially had my eibach sportline springs put on today and got it sorted, looks so much better, now got the hard part of deciding what wheels to get
    Jan 2012
    surrey
    19
    before
    after
    harvz likes this.
    Dec 2012
    205
    what size eibachs did you get? have you kept the standard sport shocks??
    Feb 2004
    Borders, Scotland
    371
    Looks much better, be interested to know what the Eibachs are - ?? as well and if anybody knows what the differences are between Standard and Sport, Standard and S-Line etc ???
    Stol1975's Avatar
    Sep 2012
    227
    Don't u like the wheels u have on now?
  1. S6 Rear brake caliper..help!
    By crispin in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2007, 13:06
  2. rear brake disc help, now
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st May 2007, 22:12
  3. Sourcing a rear bumper? Please help!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2006, 22:33
  4. S-line rear bumper fitting help!!!!!!!!!!!!!!!!!!!!
    By Arf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2006, 10:37
  5. s3 rear arch moulds
    By sammybaby in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2005, 12:41
