AH FabricationsChris Nott
Results 1 to 9 of 9
    Feb 2013
    Grimsby
    1,094
    Tyres! i need the FACTS not the opinions.
    i cant seem to find a solid answer on the interwebs so here goes...
    Right... tyres on the A3, standard is 225/45/17 correct? now as far as i understand with the naked eye 245 is a wider tyre. the wheel size would be 245/40/17 which would be overall slightly smaller but mostly the same.
    Now am i right in thinking a 245 has more grip over a 225, obviously of the same tyre?
    So if the answer to the above question is YES, how does the SIDEWALL affect grip in a straight line? or while cornering? or is the sidewall still big enough at /40/ to not make a difference?
    Ok second set of questions.
    Why doesn't everyone have the widest tyre they can fit for better grip and just general safety? (what do the high powered S3's run?)
    Quattro Haldex and the use of a different sized tyre on the rear. Would this mess things up when the quattro kicks in and even show a decrease in grip? or would it not make a difference.
    And finally.
    Im guessing i can easily fit 245/40/17 on the rear with no rubbing problems, but what about the front, should i leave them as 225 in a perfect world, or would the same size also fit the fronts?
    And how can i tell if the 17" rim would support the 245?
    I apologise for the mass of questions, but its something that really has baffled me.
    Thanks alot.
    JJ.
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,214
    I don't get it, are you running a stretch ATM?
    Putting 245 would surely make a bulge in the middle of the tread as its gonna pinch the sidewalls if you put oversized tyres on a wheel
    Current: 8P3 '59 2.0 TFSI 3DR S-Line | Adaptive Bixenons with DLR's | Folding electric mirrors | Heated half leathers |
    Previous : '06 2.0 TDi Sportback in Dolphin Grey| SE | DSG | Satnav | Privacy glass | auto lights | comfort pack |
    Feb 2013
    Grimsby
    1,094
    I realise this might sound stupid bit im a newb and a bit confused lol
    2,165
    What ever you do don't run different size tyres with Quattro.
    olethalb's Avatar
    Aug 2012
    314
    use the miata tyre calculator to work out rolling radius
    40 is not a measurement more of a ratio or percentage so a 40 sidewall on a 225 will be taller than a 40 sidewall on a 205 for example
    olethalb's Avatar
    Aug 2012
    314
    olethalb's Avatar
    Aug 2012
    314
    also regards grip best options to get more grip is to have a decent brand tyre, correct pressures and 4 wheel allignment - not forgetting general condition of suspension components and bushes.
    you'll be wasting your time fitting a set of contis if your geometry is out, may as well get some wanli :D
    Feb 2013
    Grimsby
    1,094
    Right ok, thanks for that.! Has been a help, normally i stick with eagle f1 aso's so all shud br good there.
    JJ
    Jul 2011
    Bucks
    161
    Wider tyres do not always mean extra grip !
    It's more to do with the size of the contact patch, pressures, tyre compounds etc etc
  1. The facts about the K03 Turbo!
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2014, 14:00
  2. clutch on the floor - not the pedal - need some help :)
    By Simplicity in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2012, 07:13
  3. Replies: 17
    Last Post: 6th July 2011, 08:20
  4. The new GOLF - The First facts(official info/pics)
    By kak in forum Volkswagen and other VAG
    Last Post: 27th August 2004, 11:09
  5. The facts about the K03 Turbo!
    Last Post: 14th May 2004, 15:37
