EM TuningChris Nott
Like Tree1Likes
  • 1 Post By amit87
Thread: Radiator leaking coolant tip
    Aug 2012
    Milton Keynes
    86
    Hi guys,
    I have had a huge coolant leak. It was slow but then eventually got to the point had to be topped up daily and didnt want to use Radweld.
    anyways took it to my trusty mechanic and he had a look, said it was the radiator. Brought a new OEM radiator (TPS is next door to him was around £150ish I think) but he found that something attached (forgot what he called it) to the radiator behind the cross member, think like a aluminium bracket was lose and rubbing against the Rad. Caused a small crack. Checked oil cap and there was no mayo so that was definately a good sign.
    He simply took it to a aluminium specialist and had it brazed to fix the Rad and put a rubber piece between whatever was rubbing against it. Cost £50 for the brazing. Anyways he checked thermostat, water pump etc and everything was perfect so said this was the best cheapest solution and the Rad is as good as new. cost me 3hours labour too (took him around 5hours so he did me a favour)
    Anyways thought I would share my experience. £195 lighter in the pocket but its fixed with a permanent solution.
    Thought I would share my experiences in case someone else has a similar issue.
    PS my car is 2005 A3 2.0 TFSI sportback.
    Artimus likes this.
    wuta3's Avatar
    Jul 2012
    Manchester/Sheffield
    1,040
    Quote Originally Posted by amit87 View Post
    Hi guys,
    ... but he found that something attached (forgot what he called it) to the radiator behind the cross member, think like a aluminium bracket was lose and rubbing against the Rad. Caused a small crack.
    Pics? Details on what bit it was?
    ​​Programmer/Web Developer, Headphone/Amp Geek
    06 SLine Special Edition Phantom Black 2.0T FSI Quattro A3
    Done: P-Flo, RevD, Sachs Organic, Milltek TBE + Res + Sports cat
    Wanted/Next:Intercooler, HPFP, Remap
    Aug 2012
    Milton Keynes
    86
    Yep... that would be ideal but I gave all the info I had hoping maybe someone would "clock" onto what I was on about (more what the mechanic was telling me). I looked and can not see anything to take a picture of. All I think is that it was an aluminium bracket which has 4 bolts, 2 on either side which its between the Rad and the cross member that was rubbing.
    ...im afraid that is all I know . Might be useless bit of info for most people, but maybe in future be useful to that one person lol.... I hope lol
    Quote Originally Posted by wuta3 View Post
  1. Leaking coolant?!?
    By A3_'99_Tsport in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2014, 20:59
  2. B7 S4 radiator leak
    By michael63 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th July 2009, 20:33
  3. RADWELD RADIATOR LEAK SOLUTION
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th October 2008, 14:05
  4. A4 S-Line leaking coolant
    By Manics in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st July 2008, 21:03
  5. Radiator Leak!
    By tajdeol in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd April 2008, 20:04
