Volks AutosAH Fabrications
Results 1 to 9 of 9
Thread: Spacer Help
    Sep 2011
    60
    Spacer Help
    Hello, I went to get H&R hubcentric spacers fitted on my A3 last week...I am running BBS CH's and when the spacers were fitted I noticed that there was a wobble in the wheels, it turned out that this was due to the small raised portion around the centre (not the big one, the small one more towards the outside). AFAIK there are no other variations of H&R spacers so does anybody have any other possible solutions? Thanks
    Sep 2011
    60
    Surely somebody out there has a solution?
    Feb 2013
    78
    Not entirely sure but it sounds like it could be something to do with the cone of the spacer ? If i am correct there are 2 types on for aftermarket wheels and one for oem wheels.
    Dec 2012
    Hordnean, Hampshire
    157
    Doesn't sound right, got any pics?
    Sep 2011
    60
    It's the bevel edge outlined here that won't fit in they said, causing the wheel to wobble
    347
    347's Avatar
    Sep 2006
    253
    wow amazed this radius is causing the problem , looks to be undercut as well ? unless its a faulty part of course , can you try fitting spacer on the back of a loose wheel and see if you can feel if its fully seated or not .
    2010 2.0 Tfsi BE ibis white DSG , now sharked
    Sep 2011
    60
    Ya they did that too while I was standing there and the 2 of them came to the conclusion that thats what was causing the problem...also I was fitting 10mm front and 12mm back so they came from two separate boxes. There was no wobble before fitting and all 4 wobbled afterwards, the hub is straight and clean and the inner rim fits into the centre bore no problem, so to be fair, I can't see anything else that would possibly cause the problem...
    Jan 2012
    473
    Have you got genuine BBS CH or copies? I fitted Eibach spacers to mine and have no fitting issues?
    Sep 2011
    60
    Genuine...are yours genuine too ya?...I'll take a look at the eibach ones there
  1. SPACER HELP
    By tomstanley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2011, 15:44
  2. Spacer Help Please...
    By HipAl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th April 2011, 13:28
  3. Coilovers , Gonna need SPACERS? help plz
    By Deckedm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd February 2010, 09:55
  4. Spacers help
    By StagsyA4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th April 2009, 23:44
  5. Calling JAM3 & DPM.... Spacers Help!
    By EAGLE79 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th May 2007, 12:23
