AH FabricationsEM Tuning
Results 1 to 22 of 22
Like Tree4Likes
  • 3 Post By Geraldy212
  • 1 Post By Geraldy212
Thread: Fuel flap wont lock is this normal?
    Oct 2012
    176
    Good morning guys,
    I made a quick search but could find any results so i thought id ask around for some expert advice :P
    I got a Audi S3 2007 and i have noticed that the petrol flap does not lock? surely a car like this the petrol flap is locked to prevent people from stealing my fuel? I mean the petrol cap itself isnt locked either, you could just open the flap and turn the cap and take fuel if you wanted too???
    Anyways does this mean i need a new fuel flap from audi?
    Or could it be something wrong with the locking mechanism?
    Any information will be great,
    Thanks guys =]
    Will
    Mar 2013
    Chesterfield
    33
    Hello Will,
    I have a 2009 A3 8P TDIe Sport and the fuel flap is operated in conjunction with the doors/boot locks. If they’re locked so is the fuel flap; there is no independent lock for it.
    Dave
    Feb 2009
    Aberdeen
    2,613
    Follow MartayMcFly On Twitter Visit MartayMcFly's Youtube Channel Visit MartayMcFly's Instagram Channel
    Yeah, if the doors are locked then the fuel door should be too. If it's not, might need some investigating to see why.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    Jul 2007
    Hi Willz!
    Literally just had the same problem on mine this week. The fuel flap solenoid had gone... mine actually managed to lock shut! Luckily there is a manual release in the boot!
    Anyways they are approx £13-£15 from Audi to replace. You can do the job yourself but I've had a busy week so cost me an hours labor at a local specialist garage.
    D7
    Apr 2012
    N. Wales, LL22
    1,224
    no lock = mot fail
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    Feb 2013
    27
    Hi The fuel lock does not come into play till you dead lock the car,by pressing twice on the Key fob. Hope this helps
    27,089
    That's not true, the flap lock, as in solenoid, works inconjunction with single remote lock signal, not double.
    If you want to test the flap lock, just leave the flap open, then lock the car & you'll see the bar slide out.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by honeybear View Post
    You don't have to double lock any Audi.... The deadlocks operate whenever you lock it with just one press of the remote.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Mine also does not lock, been through two MOT's with it like that and nobody has spotted it. About time I fixed it. Where is the solenoid located? How is it replaced?
    ....................I'll make a build thread one day.
    Sportback owner
    Apr 2007
    France
    492
    Remove the right-hand rear interior trim. See the locking pin actuator. Disconnect the wiring (check it for breaks and/or corrosion on the pins). Slacken the two retaining screws by two turns, and then slide the actuator forwards to release it from the body panel. The pin may be jammed or perhaps the solenoid coil has failed. You can test it outside the car by applying 12volts. Be careful, it moves very rapidly, so keep your hands out of the way.
    Digzz, MartayMcFly and MTRL like this.
    French A3 Sportback 2006, 2.0L 140 TDI, DSG, RSN-E, Ambient lighting, Auto-lights/wipers, Reverse assist, Dolphin Grey, 17" wheels, Leather seats, Cruise control, Roof bars.
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Thank you
    Oct 2012
    176
    Thanks for all the comments guys, but ive locked the car and still no luck, the flap can be opened even when the car is fully locked.
    I will check next time to see if the bar thing slides out when i press the lock button, If it doesn't slide out it means i need a new solenoid? or locking mechanism?
    Hope its as easy as you all say it is :D
    Thanks guys
    Will
    Sportback owner
    Apr 2007
    France
    492
    Willz, this is a very simple locking mechanism. A steel pin, actuated by a 12volt solenoid just moves forward to engage a hole in the fuel-cap to lock it closed. Either the pin is frozen in the actuator, or the solenoid coil has failed, or the pin is not centred in the hole, or there is a connection problem. Should be obvious if you take the actuator out and have a good look. Maybe a case of 'WD40'?. Good luck.
    Digzz likes this.
    Oct 2012
    176
    Quote Originally Posted by Geraldy212 View Post
    Thanks for the reply mate,
    I will take another look at it when i get time possibly next weekend :P
    Thanks alot for the info
    Will
    Digzz's Avatar
    "Started From The Bottom"
    Jan 2009
    London
    1,383
    I have this issue too ..... Thanks
    Sep 2012
    Prague, CZ
    88
    I have the same problem on mine, would someone be kind enough to provide the part number for the solenoid? I have a 2009 3DR 8P3.
    2009 A3 TDI 170 STronic SLine
    Sep 2012
    Prague, CZ
    88
    Quote Originally Posted by BenC00 View Post
    I think I found it, is this part number for a 3 door or 5 door? 8P4 862 153
    27,089
    I have a working solenoid here if interested.
    Feb 2008
    Europe
    231
    I had the same problem. Solenoid and central convenience ECU were replaced under warranty but problem was not solved for over a year, until I contacted Ross-Tech for some advice who gave me the solution after sending them some logs.
    I had changed settings for auto closure of windows and roof with VagCom but I took those from a forum I cannot remember that were probably not for my car. Audi service resetted all settings and everything was fixed. Then, I did the auto closure mod correctly with the long coding helper.
    Hope this helps.
    Sep 2012
    Prague, CZ
    88
    I'm in Prague so I would need it to be posted here, so I may as well buy new from Audi as they aren't expensive.
    Could you confirm the part number please?
    Sep 2012
    Prague, CZ
    88
    In case this is of use to anyone, here are the part numbers as confirmed by Audi:
    2 door part # 8P0 862 153 A
    4 door part # 8P4 862 153
    Sep 2012
    Prague, CZ
    88
    Replaced the faulty solenoid over the weekend, it was a 20 minute job, here is a quick How To in case it is useful to anyone;
    - In the boot, remove the parcel shelf, boot carpet, flip seats forward and then remove the right hand side interior trim.
    - Disconnect and remove the BOSE amp to reveal the solenoid
    - Using a good pair of pliers, loosen the 2 securing screws by 2 turns, then slide the solenoid forwards (towards the front of the car)
    - Extract the faulty solenoid
    - Swap the clip and red plastic manual lock release wire to the new solenoid
    - Install the new solenoid, carefully lining up the locking bar into the small hole at the fuel cap
    - Secure in place, reconnect the wire and confirm if working by locking / unlocking the car
    - Re-install BOSE amp and all interior trim parts
  1. my a6 keeps locking itself is this normal?
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th October 2006, 19:38
  2. headlights are apaulling, is this normal
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th January 2006, 22:52
  3. Bad Fitting Fuel Flap
    By Boyakasha in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd December 2005, 12:16
  4. Picked up S4 - is this normal?
    By imported_SunDiver in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th February 2005, 00:11
  5. Sound on acceleration - is this normal?
    By imported_bantam1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2004, 22:48
