Badger5JMB Retrofits
    Apr 2013
    a3 2.0 tdi 140 (bkd)
    hi having problems with ma a3 tdi 3 weeks ago the car cut out and wouldn't start the next day it started for 10 min then cut out again checked for fault codes but none came up replaced fuel filter the next day and car started and had been ok till Thursday.when it started to run rough then cut out and would not start checked for codes and p0202,p0203 injector 2,3 open circuit.so cleared codes but still wouldn't start checked injector resistance all ok.put back together and tried to start and car started for 10 min with a few misfires and then it cut out.and wont start again with the same two fault codes back.any info would be great cheers scoty
    Feb 2011
    Plymouth
    1,135
    Break in the wire somewhere on the injectors, could be a bit intermittent though.
  1. lift pump question 2.0 tdi 140 bkd
    By nokia_aid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 06:29
  2. Boost issues TDi 140 BKD
    By n25gabe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th September 2011, 12:35
  3. audi a3 2.0 tdi 140 BKD 8P Turbo removal? Help!!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th September 2011, 23:30
  4. 2006 A3 TDI sportback BKD 140 engine oil filter?
    By Geraldy212 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th March 2011, 11:31
  5. A3 2.0 TDI 140 BKD Juddering 5th/6th Gears under load
    By a3sportback54 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd October 2010, 11:13
